02-20-2020, 01:43 PM | #45 |
589
Rep 897
Does anyone have any service forms they can sent over? BMW Denied my claim for the ticking noise. Mine has been mild, but slowly getting worse..
02-20-2020, 02:42 PM | #46 |
Rep 389
Shoot me your email via PM and I'll send you mine.
'01 M Roadster, '24 BSM M2
09-21-2020, 07:51 AM | #47 | |
Rep 21
Hi, You're car is ok ? puma case #64203791_02. I have this problem. THIS IS A POOR TIGHTENING OF THE CAMSHAFT SEE Y LATER |
tpreston03318.50 |
01-04-2021, 01:27 PM | #48 |
Rep 16
Ticking and Fluttering Noises
Sounds like I have the same issue. Started happening sometime after having the 1200 mile break-in service done. Could it be due to going from a thicker oil that is used when the car is first delivered to the thinner one that is used for the service? Curious if the thicker oil keeps things lubed better when not running because maybe it sticks to the components more. I only drive the car a couple days per week, so I tried driving it every day for 4-5 days to see if that helped, but no improvement. It only has 1800 miles and it's 18 month old. The issue only happens during cold starts and also only happens when in the 750-850 RPM range, then goes away when it fully drops to 600-650 idle. However, I can get the noise to come back if I am able to hold RPM's around 750-850. Does this sound like the same issue as others have had with the incorrect tightening of the cams or something else? I've also noticed a fluttering sound coming from the engine somewhere between 1250-1750 RPM and around 2500 RPM. It doesn't come across in a video, but I can definitely hear it in the cabin when it's fairly quiet. It also started happening after the break-in service. Searching around the internet and the closest thing to the noise I could find is this. https://f80.bimmerpost.com/forums/showthread.php?t=1612812 Anyone else have the "fluttering" noise? Last edited by Silpher; 01-04-2021 at 01:41 PM.. |
01-14-2021, 06:17 PM | #49 |
Rep 769
Same exact sound here in F80 M3 as the OP and as the guy above. I had this sound since 20k miles (45k miles now) and multiple track days. Is it worth fixing it our of warranty? Is it really bad that i had it for so long?
11-22-2021, 11:54 PM | #50 | |
Rep 5
I have the same ticking noise from my m3 |
11-23-2021, 06:56 AM | #51 |
Rep 8,972
Mine does it, but I'm not concerned as it goes when warmed a little and other wise all is sweet sounding.
Most engines make some odd noises when cold, especially with the bonnet / hood open. |
11-23-2021, 01:25 PM | #52 |
Rep 4,255
Sounds like lifter tick. Warm the motor up all the way and then take the motor to redline a few times. This is how the lifters are bled.
///M Power
11-23-2021, 02:19 PM | #53 |
Rep 8,972
Yeah meant to say sounds just like a hydraulic lifter might need a good hammering..
The S55 lifters are just bog standard cheap ones shared with pretty much every other petrol BMW engine. https://www.realoem.com/bmw/enUS/par...&q=11337548690 Last edited by doughboy; 11-23-2021 at 02:28 PM.. |
11-26-2021, 10:59 AM | #54 | |
Rep 4,255
https://www.rtsauto.com/bmw-e90-valv...ter-ticknoise/ All BMWs are basically the same. With my S62 the procedure involved driving hard and taking the motor to redline when hot. There are variations of this SB everywhere in BMWs model line. The long and short of it is you need to get the motor up to temp and then DRIVE the snot out of it. It's interesting because since these cars are so crazy capable and generate so much torque in low RPMs, short-distance trips and long periods of time without touching redline are going to make lifter tick more prevalent.
///M Power
smknjoe234.00 |
11-30-2021, 08:50 AM | #55 |
Rep 27
I had a similar noise to OP's post.
My car made a weird tapping noise on cold start, which sounded like it was coming from the top end of the engine. At the time my car had approx. 23k km / 14k mi. Refer to the links below which clearly show the difference between how the car sounds on a cold start and after its warmed up (after an approx. 30 minute drive). Cold Start: https://youtube.com/shorts/QDf9iBTSk0o?feature=share Warmed Up: https://youtube.com/shorts/s3cdcPjblsE?feature=share I took it in to the dealer for them to inspect it and carry out necessary repairs. Overall, they carried out maintenance work on the exhaust camshaft. They replaced the gasket, 6 decoupling elements B13537628063 and 4 decoupling elements B13537577649. Car sounded fine when I picked it up. I'll refer back to this post if anything else comes up. If anyone can explain the following, I'd really appreciate it: 1) The function of decoupling elements 2) Whether them failing caused any premature wear or damage I need to be aware of |
03-02-2022, 07:20 PM | #57 |
Rep 216
04-03-2022, 12:47 PM | #58 |
Rep 87
05-09-2022, 03:42 PM | #59 |
Rep 54
I hear this jingle . A kind of Din Din ....non is very noticeable , can be heard when the hood is open , when the hood is closed it is almost imperceptible , but I do not like it . It seems to me different from those reported in this post . Car has 43,000 km . In the coming days I want to pay attention if there is a difference between cold engine and warm engine .
05-09-2022, 03:49 PM | #60 | |
Rep 8,972
The cam knock noise is slower (1 per 2 revs) and more metallic. Mine has the suspect cam knock noise, getting worse, I'm taking it to my indy soon for spark plugs and service and while it's in I'll them to get the cam cover off and check it.. Last edited by doughboy; 05-09-2022 at 03:55 PM.. |
05-10-2022, 04:59 PM | #61 |
Rep 54
Some updates : the rattling is only heard when the engine is hot . I checked oil level and it was just above half level . I added 0.7 liters of oil to bring the level to the maximum. The rattling seems to be gone at the moment.
06-27-2022, 08:26 PM | #62 |
Rep 160
Same noise as OP. Brought to two dealerships and they both said it's a normal sound and shoo'd me away after keeping the car for a few days…
Anything I can do to escalate this issue and have them actually do something? Still under warranty for another year. |
07-07-2023, 07:45 PM | #63 |
Rep 144
2020 M2C here. Had the exact same sound and the dealer fixed it following the PUMA case #64203791-02. Basically they tightening the exhaust cam shaft. No more knocking sound.
05-05-2024, 08:40 AM | #64 |
Rep 247
https://youtube.com/shorts/mV5srq_oq...1dWyHYHUDRJIld
I’m having this issue as well but my noise seems a tad bit more irregular sounding. It does not go away when the car is warmed up. Any thoughts on what this could be?
08 E92 M3
16 M4 17 M2 17 M4 ZCP 18 M4 ZCP ( Current ) |
05-05-2024, 10:49 PM | #65 | |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
184
Rep 303
05-06-2024, 07:05 AM | #66 |
Rep 247
Mine is actually the opposite when it’s warming up it doesn’t make any noise
08 E92 M3
