11-26-2019, 05:18 PM | #45 | |
Rep 427
Ha! Zoomed in as close as I could on a bigger screen and I think you’re right. The light/shadow got me. Oops. The back end definitely feels like it skips over bumps due to what feels like a spring rate/damper mismatch, while the front just sucks it all up, so I guess I saw what I wanted to see. |
11-26-2019, 05:27 PM | #46 | |
Dirt Junkie
116
Rep 76
Drives: 2020 BMW M2 Competition
It is a bumpy corner but your weight transfer has already happened so that back wheel is on the ground. Glad what I posted agrees with your thoughts too.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW-What a Ride!'" - Anonymous
11-26-2019, 06:36 PM | #47 |
Rep 2,685
Drives: '24 X7 M60i
I might come out on the 15th. I still have my credit from missing AMP. However, I'm hoping my buddy brings me as his guest to Apex.
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
11-26-2019, 06:46 PM | #48 |
Rep 427
11-27-2019, 11:46 AM | #49 | ||
Rep 3,549
As an example, at ACNA Sonoma at the beginning of the month a bunch of drivers were talking about how rough the curbing was at T2, and T8. My friend and I found that amusing because our vehicles (435i on Ohlins R&T and 328d on FCM reworked Bilsteins) handled all the curbing very smoothly. On the 435i I turned down his dampening from the Ohlins recommended "track" setting the weekend before to optimize things. This made the car less harsh and upset over bumps like track curbing and let him attack corners with more speed. He said the car felt smoother and more in control. On my own setup my dampers don't have any rebound bias. My instructor even mentioned how comfortable and smooth my ride was over all the curbing.
12-06-2019, 10:45 AM | #50 | |
Dirt Junkie
116
Rep 76
Damping (not dampening, that's what you do with a wet cloth) - The control of motion (via the shock). So when you say rebound is too high (as in motion?) - do you mean that it's too soft so it rebounds too quickly? Or do you mean it's too stiff (as in the setting is too high) and the rebound is slow? I feel that there needs to be more rebound damping (slowing the extension of the shock). Presently the rebound is too fast and it's allowing the suspension to extend too quickly so the car feels jumpy. The rebound action needs to be slowed down. Slowing down the compression damping a tad will also help as right now it feels like the suspension blows through the travel and (as you've stated) lets the car get to the bump stop and then there's no wheel travel left to deal with undulations of the track. That "packs" the suspension up and it can't do anything anymore. Too much damping on compression will also cause "packing" as the shock can't respond quickly enough so it acts like it's on a bump stop. The car needs better rear damping control - more rebound resistance, a slight increase in compression and I think it needs to get away from progressive rate springs. They get stiffer more quickly and the valving in the shock needs to be able to do the same (shaft speed control). As you get to the limits of extension or compression you start taxing the limits of the damping control with progressive rate springs. Just for background on my suspicion of what's needed, I have about 25 years of suspension tuning under my belt in the off road world. I'm used to controlling 20+ inches of travel with (generally) three zones of damping in compression and two in rebound along with playing with spring rates, cross over points of the springs and such. Lots of time (43 years) on motocross bikes too. Present project - can't wait to start suspension tuning on this.. :
Commanderwiggin2056.00 Bosozoku695.00 |
12-06-2019, 12:34 PM | #51 | |
Rep 3,549
With your off-road rig experience, you're probably very familiar with not having such a high rebound-biased setup too.
12-07-2019, 08:32 AM | #52 | ||
Dirt Junkie
116
Rep 76
12-17-2019, 10:42 AM | #53 |
Dirt Junkie
116
Rep 76
About 550 miles worth of track time (17-18 sessions) on this set of Toyo R888Rs.
This past weekend the front end started letting go more often (had one hell of a fun last session this Sunday - guy in a Cayman and I were having a blast and I had no front end grip). Pulled the wheels off yesterday to put the car back in street mode and was quite surprised at the inner edge of the fronts! - realizing that I have to look a lot more carefully while they're on the car, as I can't see the inside edge very well. I am quite positive that there were no cords showing before I started playing on Sunday, though. They had to be really close to the surface, though. I'd say that 2.85 degrees of negative camber is a bit much. The right side tire wasn't as worn as the left (pic) but I'm seeing cording there too. Rears at 1.8 degrees are also showing signs of too much camber. Gonna drop the fronts to 2.2 and the rear to 1.4 and see what that does to spread the load a bit better across the contact patch. Interestingly the surface temps were pretty similar across the tire's width - 140 to 150 was the margin. I didn't check the rears. Not an excuse, a realization, I need to be a bit more up on checking things during the day. Having students definitely cuts into available time but it's something I need to be more on top of with this car. My old R8 was set up just right so I was able to be lazy about wear checking as it was an equal opportunity tire wearing vehicle. It didn't tend to bias wear at either shoulder, which is what I'm trying to get out of this M2C. Cage is supposed to be here sometime (was supposed to show last week) and I'll be ordering another set of Toyos (they're the least expensive and work pretty well) to get the car dialed in. Ah the joys of modifying. One step forward, half a step back. Did I say how much fun I'm having with this car? What a blast it is!
12-17-2019, 11:06 AM | #54 | |
Rep 1,917
Matt
AmuroRay2379.00 |
12-17-2019, 07:46 PM | #55 |
Dirt Junkie
116
Rep 76
Interesting - you're the third person to say check toe.
I based my original settings on what I'd found here on the forum: 2.8 and 1.8 camber and zero toe. Looks like I need to find another place to do the alignment. I want to double check everything and see what it reads now that I've run it hard for a few miles.
01-12-2020, 10:28 AM | #56 |
Dirt Junkie
116
Rep 76
RSR cage and Team-Tech harness installed:
Car goes in tomorrow for Ohlins and rear camber control arms.
Ex_Stig2611.50 |
01-12-2020, 02:19 PM | #57 |
Rep 1,917
Horrible idea to run those seats with that harness setup.
Matt
01-14-2020, 09:09 AM | #58 |
Dirt Junkie
116
Rep 76
Thank you for the compliment.
Same setup I ran in my R8 - yes, they're slightly wide at the shoulders, that's why the sternum strap is there - keeps them nice and snug across my chest.
01-14-2020, 09:43 AM | #59 |
Rep 1,917
These seats are not designed for harnesses, period. If you're going this far, why not put in a proper race seat?
Matt
01-14-2020, 12:12 PM | #60 |
Rep 585
That's some pretty horrible tire wear. I've run NT01s, which are essentially the same compound from what I understand, with over 3.2 front camber and have had very even wear. Somethings off, either alignment, suspension settings, or something else.
Regarding those seats with a harness, I wouldn't run that. I don't think it will even pass tech. |
01-14-2020, 02:41 PM | #62 |
Dirt Junkie
116
Rep 76
Regarding the harness - just getting things set up. Seats will be a future thing. I'm aware of the issues the setup has.
The tires - yeah, horrible issue there. Not sure what was up. Everything checked out (supposedly) but I wonder if the machine we used wasn't quite right. Dunno. Regardless, the car's getting Ohlins installed and there will be a full four wheel alignment done (again), hopefully with better results. I was blown away when I pulled the wheels off and saw that.
01-16-2020, 10:16 AM | #64 |
Dirt Junkie
116
Rep 76
Completely agreed. The good thing is that it's equal so what ever I screwed up I did it correctly and balanced.
Picking the car up to day with new suspension and settings. Time will tell if it's correct.
01-16-2020, 03:51 PM | #65 |
Rep 1,917
Won't you know it's correct by reviewing your alignment spec sheet?
Matt
01-16-2020, 06:47 PM | #66 | |
Dirt Junkie
116
Rep 76
Just home. The settings up front were WAAAYY off. Looks like the company I use had no clue (and I will admit I kind of wondered - I felt like I understood the system better than the guy running it - who was not the regular guy) Camber was at 3.4 and toe was in three degrees. Explains the sever cording. Aligned on the latest Hawk-Eye system: Car is now set at 3 degrees camber, zero toe front 1.9 camber, presently mentally blank on toe in - 1 degree or did he say 1.8... And now that I type this I realize I didn't get a sheet from this guy either (although I trust him - It's very obvious he does know his stuff.) I have to take the car back so he can replace the upper pivots in the Ground Control plates. They're a one time use (have a crush washer that deforms) and it was overlooked when the new spring perches were installed. Installer is covering the bushings and installation, as he should. Looking forward to getting on the track and seeing what the new legs are like.
kpaso186.50 |
