BMW M2 Forum > Regional Forums > AUSTRALIA > BimmerLink / Bimmer Code and Wi-Fi BT OBD Adapter
      03-22-2018, 05:00 AM   #45
terrywang
terrywang's Avatar
96
Drives: OG F87 M2
2016 BMW M2  [0.00]
A stupid question: do you guys buy both BimmerCode and BimmerLink (more for diagnostics)? I don't think they overlap much so if I need to read real-time statistics and check diagnostic messages, I'll need BimmerLink?
They will cost A$42 * 2 -_-z
2016 F87 M2 DCT LBB
      03-22-2018, 08:38 PM   #46
V.Smurf
V.Smurf's Avatar
164
Drives: M2 LBB DCT (LCI) | X3 30i
Hi terrywang,
I have only used Bimmercode: until the recent posts on this thread, and the main Bimmercode thread, I'd not been aware of Bimmerlink.
I find that Bimmercode is useful for (re)programming most of the stuff that I'm interested in setting. I recently had to recode a bunch of settings following an ISTEP update the dealer performed ... and then I coded the comfort access with the seats.
Its a really useful application, particularly as it very easily gets rid of a bunch of nuisance alerts like that stupid legal warning that interferes with everything (except the reverse camera).
I can't speak for Bimmerlink: looks like its useful if you want to monitor settings or play around with alerts (as you've surmised). The good thing is that it seems to use the same VGATE adapter that Bimmercode uses.
Cheers,
      04-03-2018, 09:22 PM   #47
m34m
Drives: E90
Is there one OBD adapter that works with both Bimmercode and Bimmerlink? Don't want to buy two.
      04-03-2018, 10:18 PM   #48
Who?
Who?'s Avatar
487
Drives: F87 LCI
Originally Posted by V.Smurf View Post
Hi terrywang,
Cheers,
What is the seat comfort access under? cant seem to find it
my wifi module work with both bimmerlink and bimmercode
use the link to get rid of errors caused during DIY (most recently, the airbag error caus I forgot to disconnect the battery) and to open/close the exhaust valve for some amusement.
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      04-03-2018, 10:33 PM   #49
V.Smurf
V.Smurf's Avatar
164
Hi Who?,
Comfort Access (aka seat coding) is discussed in the general Bimmercode thread, however there is a dedicated thread which is what I used when configuring it. I used the settings listed, but I seem to recall that there was another thread/post about how you could further customise the movement (to further control the amount of movement).
That said, you need to have Bimmercode in Expert Mode, which I recall means you need to pay for it. I paid for it anyway as I thought that it was a pretty good app and decided to support the developer who was super responsive when I asked questions
Oh, and you need to have electric seats - so unless you purchased the M2 Pure, you should already have these as standard.
Happy coding!
Who?486.50
      04-29-2018, 03:13 AM   #50
Who?
Who?'s Avatar
487
Drives: F87 LCI
Hi Who?,
Happy coding!
Thanks mate
Just tried giving this a crack, but on bimmercode, after 3012 eah, there doesnt seem to be the options specified?
      04-30-2018, 06:57 AM   #51
V.Smurf
V.Smurf's Avatar
164
Hi Who?,
You're right: I can't find it. I'm a bit perplexed - I found this easily last time, but this time around I've been unable to locate it..?
I've dropped the developer a note to see if there is something obvious I'm missing ... but when I coded it last (and this would have been in early March, so not that long ago) it was a snap, so maybe an updated Bimmercode version has removed it..?
I'll let you know if they come back with an answer
Cheers,
Who?486.50
      04-30-2018, 07:08 AM   #52
Who?
Who?'s Avatar
487
Drives: F87 LCI
Hi Who?,
Cheers,
legend
      04-30-2018, 05:31 PM   #53
V.Smurf
V.Smurf's Avatar
164
Hi Who?,
legend
The developer wrote back and told me that he hadn't changed anything, and suggested using the search feature in Expert mode. I can try this later tonight when I'm home, but in the meantime I did a search and I found the original post that I used to find the Bimmercode parameters.
As I was in a rush last night, I didn't look for the Expert mode button when I was fiddling around in the Seat Options, which is what the post suggests ... probably as it hides down the bottom of the screen and isn't obvious Its annoying as I spent plenty of time in Expert mode for the FEM and Head Unit! Anyway, the Seat Module Driver and Seat Module Passenger are found on the main Bimmercode screen: my recollection is that I coded both of these.
I'll report back when I've had a chance to check this further tonight.
Cheers,
      04-30-2018, 06:37 PM   #54
Who?
Who?'s Avatar
487
Drives: F87 LCI
Hi Who?,
Cheers,
yeah i went into expert mode, but the Seat Module Driver and Seat Module Passenger are limited in dropdown(?) menus
i wonder if its to do with the idrive update from the dealer cluster recall update
      04-30-2018, 07:00 PM   #55
V.Smurf
V.Smurf's Avatar
164
Hi Who?,
Ok - well, I didn't miss them last night then. I'll have a better hunt around tonight and see what I can find.
I'm certain that this isn't the case as I coded my seat movement after I'd had the ISTEP update applied in FebruaryL: I fixed up a bunch of stuff that had been broken by the ISTEP update and took the opportunity to code the seat movement.
What I can't work out is where this has disappeared too as it was so easy to locate last time. My memory is that it was on an extended list of parameters when in Expert mode, but I just couldn't find it this time around. Have you tried using the Search feature to locate "EINAUSSTIEGSHILFE" or "3012" ...?
I'm sure something has changed, but I'm going to try the Search function the developer suggested to see whether it locates some of these parameters before I let Stephan know that the functionality seems to have disappeared.
Cheers,
Who?486.50
      05-02-2018, 03:32 AM   #56
V.Smurf
V.Smurf's Avatar
164
Hi Who?,
Turns out that Expert mode is actually there I've taken a look tonight - its in the bottom left corner (so not always obvious).
Anyway, I decided to write some detailed instructions on how you do this - hopefully it'll guide you through the process.
If Expert mode isn't showing up on your Bimmercode app, then you probably are just using the free version
Hope this helps!
Cheers,
      05-02-2018, 03:34 AM   #57
Who?
Who?'s Avatar
487
Drives: F87 LCI
Hi Who?,
Hope this helps!
Cheers,
yeah i went into expect mode, as i paid for the app, but some of the options are missing. ill do a screen grab on the weekend
      05-09-2018, 11:59 AM   #58
rocke29
rocke29's Avatar
Drives: 2018 LBB M2 M/T
Hi Who?,
Hope this helps!
Cheers,
Hi Who?,
Hope this helps!
Cheers,
Same here. I got my car serviced and have to recode but much of the selections are now greyed out in BimmerCode. Yes I did pay for it.
      05-09-2018, 06:41 PM   #59
Who?
Who?'s Avatar
487
Drives: F87 LCI
So the Devs responded to me stating I have the newer software, and BMW changed this with the most recent update..
I also uninstalled/reinstalled the app prior to this with no avail..
i guess we're out of luck on this one
      05-20-2018, 06:12 PM   #60
terrywang
terrywang's Avatar
96
Drives: OG F87 M2
2016 BMW M2  [0.00]
Not planning to go back to dealership for services so I guess I am good for this ;-)
2016 F87 M2 DCT LBB
      05-30-2018, 12:56 AM   #61
Zuzu
Zuzu's Avatar
2828
Drives: M2C HS 6MT
Just received my iCar ( Vgate ) Pro Bluetooth OBD Adaptor to connect with the BimmerCode app.
Got straight into coding and can't believe how simple this is for even a novice.
I can recall coding my 135i vert back in 2009 with a laptop program and it was a absolute nightmare
      05-31-2018, 12:25 AM   #62
terrywang
terrywang's Avatar
96
Drives: OG F87 M2
2016 BMW M2  [0.00]
That was the terrible E-Sys system I believe, poorly designed software (UI), not intuitive at all.
2016 F87 M2 DCT LBB
      05-31-2018, 03:49 AM   #63
Zuzu
Zuzu's Avatar
2828
Drives: M2C HS 6MT
Yep..sure was.
On the bright side, Coding OFF the ASD is the absolute bomb.. What a friggen difference, especially with MPE
      06-10-2018, 08:34 AM   #64
kravz
Drives: M2 LBB
Second the asd off. sports is so much more bearable now lol
Been driving in mdm mode but with the weather it's slippery
I did the door lights on reverse then it threw errors like left high beam malfunction and my heart sank... luckily it was all good when I restarted the car lol
      12-02-2018, 03:21 PM   #65
Proctor750
Drives: E30 M3
Can you still change the door open sound or seatbelt sound to rolls royce or did that go away with the newest istep version?
      12-03-2018, 12:03 AM   #66
yawn
Drives: M2 Competition
Anyone had issues with bimmercode and warranty?
