09-20-2017, 02:09 PM | #45 | |
Rep 121
correct. that's racecar driving 101. the following needs to be down BEFORE the turn: Down shift to the correct gear depending on the speed in the curve, you can skip gear. Brake to the correct speed that you can carry in the curve. try not to shift or brake when the steering is turned. But this is basic. There's advanced skill, that you can trail brake or accelerate to exit. But try not to shift during the turn. |
09-20-2017, 02:30 PM | #46 | |
Space Force - 4 Star General
11484
Rep 3,265
I absolutely hate the lack of engine braking in my M2. Engine braking and exhaust sound are the only two things I really miss about my old 370Z. |
09-20-2017, 02:55 PM | #47 | |
Rep 1,466
In older cars, the valve opening and closing was fixed, and the fueling was determined by a carburettor which mechanically determined the fuel based on the vacuum in the intake, and the ignition was mechanical. Over time, each of these has become controllable, and I think I read somewhere that the M2 throttle is not controlled with a traditional throttle body with a butterfly valve, rather the throttle is adjusted by the amount the intake valves open. In addition, the fuelling and ignition are also controlled by a computer. If that is the case, when you take your foot off the gas, the ignition can be switched off, the fuel can be switched off and the intake valves and / or exhaust can be controlled to prevent loosing speed, which will of course increase economy. If your 370Z had good engine braking, I'd assume (since it's not that old) that although the fuel and ignition could be disabled, the valves could not be controlled, so you still had the same amount of engine braking as an older vehicle.
2018 ///M2 LCI, LBB, 6MT...
DETRoadster11484.00 |
09-22-2017, 10:49 AM | #48 |
589
Rep 897
In Sport or Sport+ the engine braking is still there, especially if you're light on the brakes at higher revs.
09-22-2017, 11:00 AM | #49 |
Rep 306
Drives: MY17 LBB M2
09-22-2017, 12:26 PM | #50 | |
Rep 2,948
Another is the fact that current high perf engines (especially the turbocharged ones) have way more torque compared to the older ones, so a missed shift can cause much more damage to the engine because it would get slammed with all this torque. Another minor one is warranty. Many brands now include much longer warranties than in the past, so if you want to protect what you're warrantying, you have to 'nerf' the car a bit so people like the OP, who has little experience, don't destroy an engine by accident triggering a replacement. Now, the M2 still does provide some engine braking, and the amount increases as you go from Comfort -> Sport -> Sport+, with Sport+ being the most intense of the bunch, where you can actually feel it. |
09-22-2017, 07:58 PM | #51 |
Rep 360
I just checked the read out today - in the pre LCI, the middle indent in the temperature bar corresponds to about 90C on the oil temp readout on the M Performance LED display steering wheel. I thought the centre indent was the OK. In any case, I am still running in the car but the MDM mode and the M Performance exhaust is sooo soooo good sounding.
09-23-2017, 07:42 AM | #52 |
Rep 3,968
Wow - I am shocked at the "rules" for downshifting/clutch/etc. I read them and was thinking no way could that be the case (especially the silly UK rules)- but sure enough, a little research and they appear to be correct.
And I guess that's why I hate rev matching so much because, each and every morning, I come up to a slow right hand turn doing about 40mph. I'm normally in 4th, I depress the clutch, start braking, and select 2nd only to hear the engine rev like crazy. I continue to slow down - clutch still depressed, disengage clutch, make the turn and then motor on. If I am reading this malarkey* correctly, I'm supposed to stay in 4th, brake, then select 2nd just before the turn - right? *and just referring to it as malarkey as I'm in shock that these are the rules/best practices. I would think that my ability to get out of the way of someone would be severely hampered if I was in 4th gear at 10mph. For instance http://www.drivingtesttips.biz/changing-gears.html Talks about staying in 5th until almost at a stop - that sounds terrible from a safety perspective.
09-23-2017, 09:28 AM | #53 |
Rep 306
Drives: MY17 LBB M2
I think the idea is you are supposed to “ignore” what gear you are in and only brake when slowing down (of course having the clutch pedal depressed). Then you put it in gear when you are about to give it gas.
It is the “safest” method, since you are only focusing on braking. |
09-23-2017, 10:10 AM | #54 | |
Rep 3,968
and I just noticed, I clutch in before braking - always.
09-23-2017, 12:34 PM | #55 |
Rep 306
Drives: MY17 LBB M2
09-23-2017, 01:19 PM | #56 | |
Rep 197
09-23-2017, 06:06 PM | #57 | |
Rep 1,466
In an emergency situation, like a child running out in front of you, the idea is that you stop as quickly as possible, the intention then is to make use of engine braking if you can, by staying in gear, even if it's a high gear, until you stop. If you're a good driver, it would probably be best to shift down through the gears to maximise engine braking, but I'd question if in such an emergency you'd a) have enough time to think through what the best coarse of action is, and b) if it would actually be any quicker. A basic rule though is that you should never be coasting (clutch in, and therefore out of gear), even if you're braking. If you're driving sedately then you could shift down through the gears as you slow down so that you're always in the correct gear to take any action, and if you're driving more aggressively, you might skip gears like 4th to 2nd etc. The chances are that if you're driving more aggressively, you might chose to skip down to second and end up at 4,000 rpm, because you'd rather be in that part of the power band that 2,500rpm in 3rd. Coasting in neutral or in gear with the clutch depressed isn't a good idea, because the car handles best when it's either braking or accelerating. In neutral it's doing neither of those things. You could argue that you're OK because you're braking, and that's true, but at some point you've got to go back into gear, and this change has the potential to upset the balance of the car, whereas if you did it during the braking phase, that would be less likely to happen. The UK driving test rules are intended to be a guideline for new drivers, who drive sedately. There are other rules like 'feeding' the steering wheel rather than crossing your arms, which is very slow, but is safe at sedate driving speeds. If you take advanced driving lessons in the UK, 'feeding' the wheel goes out the window, but that's because it's for advanced drivers, not for learners.
09-23-2017, 06:37 PM | #58 | |
I INDIC8
612
Rep 1,290
Drives: 2018 LBB M2, 6MT
In your situation posted earlier, you're coming up to a low speed turn and you know that 4th will be too high of a gear. you should downshift to 2nd before you get to the braking point. The car will rev-match for you (this saves clutch wear, it's good!) and your clutch should be out / re-engaged by the time you are braking. If you don't need as much power getting out of the turn, you could downshift to 3rd instead of 2nd. Generally, as long as a car is still moving, it won't stall in 3rd at 15-20.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 09-23-2017 at 06:47 PM.. |
09-24-2017, 10:09 AM | #59 | |||
Rep 3,968
1. Clutch depressed causes no wear to clutch (throw-out bearings yes) 2. If I were to do an emergency braking maneuver and car was in gear - I'm positive it will jump a bit at the end as the engine stalls - so clutch in braking is (in my argument) faster/shorter - at least with modern cars. 3. "..the car handles best when it's either braking or accelerating" - that's incorrect - the car can turn, stop, or accelerate - and it does each of these best when done independently (especially the stop/accelerate - but you get the idea ). It is a good idea to slightly load up the front prior to a turn and start accelerating out of a turn - but during the turn, you don't want to be doing either of these (unless you have a bunch of 13 year olds in the car telling you to powerslide!) Quote:
09-24-2017, 12:37 PM | #60 | |
Rep 1,161
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
09-24-2017, 03:04 PM | #61 | |
Rep 197
Regarding what you do, that's exactly how I drive.......clutch in, slowing down as I downshift, then make my turn with the clutch still in, and then let it out as I'm completing the turn and driving off. |
09-24-2017, 04:49 PM | #62 |
Rep 1,466
I'm not a raceing driver, so anything I've said comes from what I learned when I learned at 17 in the UK.
Your approach doesn't sound correct to me, but it's just my opinion, and I didn't mean to offend. Likewise, my approach doesn't sound correct to you, and I'm taking no offence either. Juts a shame there isn't an 'authority' on the matter, because I for one would love to know the correct approach(s) from the point of view of efficiency, performance and minimizing wear and tear, each with safety as the biggest priority.
09-24-2017, 05:50 PM | #63 | |
Rep 642
From what I am reading, please correct me if wrong, that some are actually going through the turn with the clutch in, basically coasting, and then letting the clutch out and so on. In almost every situation one should have already established the proper gear based on engine revs and speed, braking as needed, and been set up prior so they can drive through the turn with power or possibly decelerating with engine braking. The vehicle chassis/drivetrain should be under torque so it has proper attitude and hence direction. The suspension will lift if not under torque and you loose grip/traction. Some advanced skills require shifting and/or trail braking while mid corner to keep balance and chassis attitude. This was especially important in more flimsy designs of prior years. More modern cars are much more forgiving and almost drive for you. I am not really fond of over regulation, but in Europe one cannot even get their license without fairly rigorous training. On motorcycles you must start out with a small displacement machine first to learn. I love the US and it's freedom, but some times I just scratch my head. |
09-24-2017, 06:14 PM | #64 | |
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
I have been driving a manual since age 16...for 44 years..and the above is based on everyday normal non track driving..highway and New York City "stop and go" driving. just my 0.02 |
M2Nebula547.50 |
09-24-2017, 06:18 PM | #65 | |
Rep 3,968
I do know - that at a track, you select the proper gear and do not leave the clutch in during the turn. As I pointed out, that doesn't work as well here on the streets of Chicago in weather. And since there is basically no engine braking in a modern car... Nezil, learned one way, I learned another - and he is correct, there is no "authority" on this for the streets as far as I know. But I think I clarified the why of my responses pretty well. and crap, I just realized, I'm old!
bruin1md69.00 |
09-24-2017, 06:20 PM | #66 | |
Rep 3,968
