M2 Technical Topics > Suspension | Brakes | Chassis > KW Height Adjustable Springs
      05-24-2017, 07:16 PM   #45
///MIKE M
Drives: 2016 LBB M2
Originally Posted by R0ME0 View Post
Thanks for sharing. Would love to see more photos!
Need to see some pictures of your car with the adjuster resmoved!!
That's my plan also as we discussed previously.
How much did it lower it as opposed to the 1.2 max??
Any complaints of it riding differently without it installed?!
Put some up on your Instagram
      05-24-2017, 07:23 PM   #46
ahgood
161
Drives: 19 bmw M2C
hi
Originally Posted by casestudy83 View Post
I am thinking of getting HAS or HR. Where did you get those parts from? Can you PM me the details ? thanks!
http://www.burgertuning.com/
      05-27-2017, 09:25 AM   #47
David1
David1's Avatar
Drives: 09 E92 09 X5
Are you sure the rear springs are installed correctly? Shouldn't the adjuster pad be at the top?
      06-05-2017, 12:52 AM   #48
bunster
Drives: 2017 F87 M2
I installed the rears KW HAS and having difficulties with the front ones. Do I need shorter sway bar links for the fronts? What am I doing wrong.
      06-05-2017, 01:32 AM   #49
Fab_R
192
Drives: BMW M2 / Audi S3 8V Sedan
No, you do not need.
      06-05-2017, 12:41 PM   #50
lax01
Drives: 2017 M2
You absolutely need an alignment (and corner balancing) after this type of install...
      07-07-2017, 03:12 PM   #51
IND-Distribution
IND-Distribution's Avatar
9609
Drives: G82 M4 / G87 M2
KW just released a new version with smaller perches. We just received our first shipment and took some photos.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
izzyM2749.50
      07-25-2017, 02:17 PM   #52
dtmpower98
dtmpower98's Avatar
Drives: F80 M3, F87 M2
Rear Adjuster
Originally Posted by HDilla View Post
Front is 19x9 et 24 and rear 19x10.5 et 34.
Wrapped in Pirelli P-Zero Tires @ 245/35/19 and 285/30/19
I'll snap some updated pics soon, I have them maxed out too. Might also need to remove that adjuster thing.
How much lower does the rear get without the adjuster?
2013 MW E92 M3
2018 MG F87 M2 (Sold)
2016 YMB F80 M3 (Sold)
Follow me on Instagram- @dtmpower98
      08-01-2017, 08:31 PM   #53
Rocket_Rod
Rocket_Rod's Avatar
138
Drives: M3 E92 & M2 F87
Could you PM me price shipped to Australia (Post Code 2170)?
      08-16-2017, 04:46 PM   #54
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
can these be installed without spacers? I'm only looking for a ~1" drop
      08-16-2017, 04:51 PM   #55
IND-Distribution
9609
Would not need any spacers for this kit.
geogerf115.50
      08-31-2017, 06:00 AM   #56
Oxymoron
88
Drives: 2018 M2 LCI MGM
I had the same setup on my E90 M3 for 5 years. Was perfect. Rides like stock and lower/more adjustable than springs alone.
Will be putting them on my M2 for sure.
      09-19-2017, 11:57 AM   #57
maddoc
Drives: E36-E82-F87-7P
What's the benefit of the HAS over say a standard spring combo? Obviously the height adjustment, but how often will that really happen?
      09-19-2017, 12:53 PM   #58
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
the fact that you can do an incremental adjustment (and when you want, as you noted).
Like for me, I would like a .8" drop, which I don't think any springs have.
      10-23-2017, 07:55 AM   #59
AK.Alexx
Belgium
50
Drives: BMW M2 on order
Looks great this HAS setup. Rides like stock. But is there a improvement when turning in? Feeling, grip?
      10-26-2017, 02:16 PM   #60
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
how can you tell if it's a new or older version? is the part # different?
      10-26-2017, 02:58 PM   #61
AutoTalent
AutoTalent's Avatar
2327
Drives: e92 M3 6mt | e60 M5 6mt
Yes, it is the same part number with a U at the end. Part # 253200ANU
AndrewC198910949.00
      10-26-2017, 03:06 PM   #62
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
A lot depends on how you have your HAS set up.
Too slammed and might look good but dynamics will be ho-hum.
One benefit of any height-adjustable setup is the option to get the car corner balanced to get more from the upgraded hardware.
      11-21-2017, 01:18 PM   #63
f87chas
Any one know what the actual spring rates are? Higher than stock? Are there any options to spring rate?
      11-28-2017, 09:27 AM   #64
alexc93
Drives: na
How will the OEM shocks handle these over time?
I know with a regular spring setup can often cause oem shocks to take on more wear/tear over time due to differing rates etc
      03-17-2018, 10:36 PM   #65
m2ligan
Drives: 2018 BMW M2 LBB
Has anyone ran these with Vorsteiner VFF-103 19x9 ET22 and 19x10.5 ET34 255 with 255/35 front and 275/35 rear? I'm worried about rubbing on the inside of the wheel once lowered.
      03-19-2018, 12:31 PM   #66
Vorsteiner_Info
Vorsteiner_Info's Avatar
190
Drives: bmw
That is our F8X fitment, it does work for the M2 however it is slightly aggressive so you would not be able to run those tires while also being very low.
We do have a dedicated M2 fitment that is 19" x 9" and 19" x 10.5" with ETs for the M2. With this fitment you would have no issue being lowered and our recommended tire sizes are 245/35 and 285/30.
