12-27-2015, 04:39 AM | #45 | ||
1131
Rep 4,686
Drives: L'Orange
12-27-2015, 04:45 AM | #46 | |
Rep 5,678
You can roll freely in a DCT too... take your foot off the brake and it will roll back. I wonder if you can bump start a car with an electronic ignition? I've never tried it but I'm not sure it would work on a car where there isn't a key??? Something interesting to try.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
12-27-2015, 05:07 AM | #47 |
Dinosaur supervisor
3033
Rep 4,214
12-27-2015, 09:38 AM | #49 |
Rep 1,668
The question if DCT is worth the money is entirely dependent on how the transmission wil be offered in different countries !
As told above, in my country the DCT is standard and 6MT is an nearly €7K option, so I could ask the same question reversed. Inmost countries however the 6MT will be standard and DCT optional. IMHO we have to split the question in; 1 Costs for respectivly DCT vs 6MT 2 What is the standard option 3 Once personal preference |
12-27-2015, 10:03 AM | #50 |
Rep 1,431
[QUOTE=
You can roll freely in a DCT too... take your foot off the brake and it will roll back.[/QUOTE] I've never noticed this when test driving a dct. So if you let go of the brake the car does not start rolling forward?? Wish I could rent a car that had a comparable/decent dual clutch (main stream rental) to get a 'feel' for what it would be like living with one. I know I can rent one at one of those high end rental spots but too $$$. |
12-27-2015, 11:31 AM | #51 | |
Rep 450
DCT not just an "Automatic"
Many of those with an apparent preference for a manual transmission either fail to or chose to not acknowledge that there really are two different "automatic" technologies being discussed. The typical conventional "automatic" transmission uses a torque converter to cause drive to engage rather than clutches. The torque converter is what is providing forward impetus at idle and causing the need to engage the brake. A torque converter based automatic has other undesirable characteristics for many enthusiasts. As drive is based on transmission fluid flow rather than a clutch, it is not a solid, but rather a fluid system. The loss of predictability of a "slush box" is what I don't want and would not buy. A DCT transmission is a totally different transmission with the drive characteristics of a clutch based transmission. It has a Drive mode that provides automatic shifting of a clutch based transmission. Yes, you can't slip the clutch to get your car to behave in a particular way with a DCT, but the trade-off is a more efficient and more engaged (drive engaged not necessarily driver engaged) transmission. SMG transmissions, the direct predecessor to the DCTs, don't creep at idle (E60 M5). I don't believe M DCTs do either. SMG = Sequential Manual Gearbox IMHO, simply describing a DCT as an automatic transmission is a disservice to its capabilities. To me, it has far more technically in common with a manual clutch based transmission that you can allow to shift automatically. I used to use the shift lever in the M5 almost as much as the paddles. That M5 certainly never got boring. As others have stated, its just a driver preference.
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
12-27-2015, 12:25 PM | #52 | |
Rep 5,678
All BMW's (including 6MT cars) have a hill hold assistant and if you take your foot off the brake, the car holds position for a couple of seconds. This is true in a DCT or MT. However, once this disengages, the car will roll backward on a hill in either transmission. Also, a DCT will NOT creep forward from a stop if you don't touch the gas. It behaves just like a MT car in this respect. If you tap the gas, it then goes into creep mode where the car will move ahead (good for heavy traffic) but only does this once you've touched the gas. Also, if you rent a DCT, make sure it is a BMW as all manufacturers can set up their DCT's differently. Porsche, for example, feels very different to me and has different characteristics than BMW. For example, in manual mode, the PDK in a Porsche will upshift at redline unless the car is in sport plus mode. With BMW, it doesn't shift unless you tell it to no matter what (the correct way IMO).
12-27-2015, 12:42 PM | #53 |
Rep 341
I mean, BMW is know for being misleading. As you pointed out they called their automatic a sequential manual. They also call a subset of their sedans, coupes. One still is missing the essential third pedal, and the other still has 4 doors but just less headroom. Whatever helps you sleep at night.
12-27-2015, 01:10 PM | #54 | |
Dinosaur supervisor
3033
Rep 4,214
12-27-2015, 01:50 PM | #55 |
Rep 341
I will concede that SMG sounds better than SAG. If I'm in the market for a manual e46 we both know I won't be buying an SMG just because some guy having a laugh in marketing tells me it's the same except for the whole manual part.
12-27-2015, 02:43 PM | #56 | |
General
17609
Rep 25,151
My M4 was all in ine, work DD and fun car, so I went DCT. The M2 is still on my radar as a second car so that would be 6MT with £3k towards the deposit
My car made front page of Bimmerpost
12-27-2015, 04:41 PM | #57 | |
Rep 13,167
(see here: http://f87.bimmerpost.com/forums/sho...24&postcount=1) -------------------
///M is art ↔ Artemis
12-27-2015, 04:43 PM | #58 | ||
General
17609
Rep 25,151
12-27-2015, 05:02 PM | #59 | |
Rep 210
I have no clue what to do. I am going to try a test ride on both a DCT and manual M4. If I can find demo cars that is. |
12-27-2015, 06:05 PM | #60 | ||
Rep 450
12-27-2015, 06:11 PM | #61 | |
Rep 450
Appears that denial is alive and well.
12-27-2015, 07:02 PM | #62 |
Rep 341
12-27-2015, 07:07 PM | #63 | |
Rep 2,234
The "M" in SMG didn't stand for "manual".
It was "Sequential M Gearbox". Quote:
But, the SMG gearbox is quite clearly a single-clutch, hydraulically actuated. It is NOT an auto gearbox and legally you would need a full manual license to drive one. |
12-27-2015, 07:37 PM | #64 |
Dinosaur supervisor
3033
Rep 4,214
Don't bother, I already tried to reason with him and it was not possible.
12-27-2015, 08:03 PM | #65 | |
Rep 450
Unfortunately, it would appear you are mistaken. I owned a E60 M5 with a SMG transmission. The name of the transmission in that car was Sequential Manual Gearbox. However it was perverted after that would not correct. This could be similar to bimmers and beamers. Bimmers are BMW cars, beamers are BMW motorcycles. These terms existed before the birth of the 3 Series and arbitrary use of the terminology does not make it correct. The following is from BMW AG's web site. http://www.bmw.com/com/en/newvehicle...ngine_smg.html
12-27-2015, 08:31 PM | #66 | |
Dinosaur supervisor
3033
Rep 4,214
http://www.bmw.com/com/de/newvehicle...ngine_smg.html https://www.press.bmwgroup.com/austr...tem=node__4266 Last edited by metrickid; 12-27-2015 at 08:37 PM.. |
