M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > DIY For LCI Instrument Cluster Retrofit
      05-15-2021, 02:44 AM   #45
3t3p
New Zealand
455
Originally Posted by beppeM3+123d View Post
If you buy used you have to erase eeprom desoldering it. If new go straight to the following simple coding procedure:
Connect to car, read fa ,inject cafd, code the kombi with oem fa of the car.
Adjust local time
Enjoy it!
That's interesting. I'm pretty good at soldering. I don't need to do it but is it hard to access the eeprom to do this?
      05-15-2021, 03:27 PM   #46
beppeM3+123d
beppeM3+123d's Avatar
205
Drives: bmw m3 dct + 123d e81
Adjust local time
Enjoy it!
Need to be opened also removing needle
      08-02-2021, 09:16 PM   #47
stardustin86
62
Drives: M3 & 335i
Originally Posted by AndrewC1989 View Post
IND-Distribution just made a vid as well
This is so useful, thank you! Where can I go to to get the coding done?
      08-02-2021, 10:07 PM   #48
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
I used bimmertech's remote coding services but any local or forum coder should be able to do it for you, either remotely or in person.
      08-04-2021, 01:05 PM   #49
3t3p
New Zealand
455
Didn't know bimmertech did remote coding?
      08-04-2021, 09:11 PM   #50
AndrewC1989
https://www.bimmer-tech.net/page-Remote-Session
      08-08-2021, 05:55 PM   #51
Matt Devo
Recovering RS4 owner
Drives: 2017 M2
2017 BMW M2  [0.00]
looks like the US/MPH part has been updated/superseded, Schmiedman lists the new part as 62-10-7-883-057. $1250 seems to be the going rate unfortunately, unless someone has better Googling skills...
      08-08-2021, 07:45 PM   #52
AndrewC1989
Unfortunately that seems to be the normal price now, perhaps due to parts shortages and the delayed after-effects of covid. I bought mine from getbmwparts in 2018 and it was only $960.
      06-15-2022, 12:28 PM   #53
AbnormallyAspirated
AbnormallyAspirated's Avatar
18
Drives: 2016 M235i 6-Speed Convertible
The Pre-Lci cluster has an oil/coolant combo gauge with no numbers
LCI cluster has oil temp only but has numbers
can anyone confirm that all F22/F23 with this level Kombi has the pre-lci IC have temp screen? I'm thinking of upgrading from my basic combi to the mid combi (pre-LCI), but only want to do it if it will gain me the temperature gauge.
      06-15-2022, 04:01 PM   #54
AndrewC1989
This is the F87 forum so it's less likely anyone here would know, especially since all US spec M2s have a temp gauge in the cluster. You'd probably find more/better answers on the 2 addicts section.
      08-22-2022, 06:21 PM   #55
HootisTigglebits
HootisTigglebits's Avatar
25
Drives: BMW M240i & BMW 330e
Is the only hardware needed to virginize and change the vin on a 6wa
• R270 EEPROM Programmer
• SOIC 8 Pin Testclip compatible with the R270
What software is needed?
2017 M240i - Estoril Blue
