04-13-2021, 11:45 AM | #45 | |
Rep 4,554
Drives: 2015 328d xDrive
https://f87.bimmerpost.com/forums/sh...54&postcount=7 |
Poochie9107.50 NYC Bimmer259.50 |
04-13-2021, 12:28 PM | #46 | ||
Luxury at the redline :)
9108
Rep 7,563
That's still about $1,500 over what I am willing to spend on this mod but I guess the price is the price and I'm assuming which is why too many people didn't bite.. |
04-13-2021, 12:35 PM | #47 |
Rep 4,554
I would have loved to do this mod as well but it's too expensive. I just ended up painting my headlight housings black for a few hundred bucks which helped them look a little better. I think the only way I'd do this retrofit is if I found the parts used and heavily discounted since buying them new is hard to justify. Like you said, idk if I'll still have this car in a few years and throwing 3.5k away for what amounts to a cosmetic mod just doesn't seem smart.
04-13-2021, 05:56 PM | #48 | |
9108
Rep 7,563
For example, recently, when they had to replace my passenger side Xenon headlight, due to a defective vertical stepper motor, immediately afterwards, they had to program the entire vehicle to the latest i-Level and "teach" the headlight module the new beam output symmetry. Had I have the LCI headlight installed, the LCI AHL (Adaptive module) would not match my pre-LCI headlight mapping and the programming would have been possible. I would then be at the mercy of third-party coders to resolve any headlighting issues.. #TheMoreYouKnow 🤓 . |
04-13-2021, 07:54 PM | #49 | |
Rep 4,554
04-13-2021, 08:17 PM | #50 | ||
9108
Rep 7,563
What model of bulbs are you rocking? May I suggest some OSRAM (BMW OEM supplier) CBI - [COLOR="LightBlue"]Cool Blue Intense[/COLOR] D1S bulb. They are 6000k color offset matches that of LED corona rings to a T and doesn't look aftermarket-ish. Try them out, I think you might like them and Amazon has a generous return policy, should you not https://www.amazon.com/Osram-66140CB.../dp/B003VNFEKO |
QuarterMileJoe9.00 |
04-13-2021, 08:56 PM | #51 | |
Rep 4,554
I have these: Philips WhiteVision 5000k They're super high quality in terms of light output, and once they're warmed up they match the white corona ring color perfectly. I figured 6000k might be a tad too blue looking so I went more conservative. They're definitely a big improvement over the stock 4300k. |
NYC Bimmer259.50 |
04-13-2021, 11:09 PM | #52 | ||
9108
Rep 7,563
I discovered them by accident, just mucking around on Amazon and realize what a gem them are - they almost looks LED-ish.. Nevertheless, if you're contented with what you currently have, then there is no reason to alternate, just throwing this out there, in case you maybe wanted a change... . |
AndrewC198910949.00 |
04-22-2021, 11:53 AM | #53 | ||
Rep 386
Did you also black out the Turn Signal Area? [if you did, did you notice reduction in light output due to you blacking it out?] Quote:
I can vouch as well. On another car I had the CBIs and remain one of my favorite bulbs. When I bought the M2 last year, Osram had recently released the CBBs. It is the same color as the CBIs but are even brighter. I suppose the only downside is that Osram claims shorter lifespan on the CBBs vs the CBIs due to the brightness. That said the CBI\CBB are a match with the Angle Eyes color and can pass for LED color as it matches perfectly to my friends Mazda 3 that has LED OEM headlights. |
04-22-2021, 04:48 PM | #54 | |
Rep 4,554
The whole housing is blacked out. I swapped my stock indicator bulbs for high powered LEDs so no noticeable reduction in light output even after painting the silver reflector area. |
StarMan351.50 NYC Bimmer259.50 |
