09-07-2018, 09:29 PM | #595 |
Rep 462
Disagree - it's awful.
I listen to Podcasts 98% of the time in the car. The other 2% the stereo is off and the windows are down. ASD is heinous. In Sport/Sport+ it honestly makes me feel like there is pressure in my ears like I'm under water. Bypass harness eta next week.
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
AndrewC198910949.00 |
09-07-2018, 10:24 PM | #596 |
Rep 221
I turned mine back on
I have catless DP + MPE and couldn't stand how quiet and subdued the car sounded with ASD bypassed. Felt like a 5 series inside and not the spirit of the M2 - still feel the car is far too quiet inside at times with windows up and backseats up. |
09-08-2018, 09:36 AM | #597 |
Rep 1,094
09-08-2018, 09:46 AM | #598 | |
Rep 1,608
Boostm3
DanG10848.00 AndrewC198910949.00 |
09-08-2018, 10:30 AM | #599 |
Rep 6,981
Drives: 2018 M2 AW DCT
I agree. I have ASD bypassed and love the car in it’s natural state. I do have the MPE so I have more noise than pure stock.
09-08-2018, 03:31 PM | #600 |
Rep 1,608
But even with stock exhaust, this car is loud inside. If folks have problems hearing the engine/exhaust inside the cabin with windows up, maybe their hearing is at issue. Or, they want the car to sound like their Harley with drag pipes.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 09-08-2018 at 08:31 PM.. |
DanG10848.00 |
09-09-2018, 06:43 AM | #601 |
Rep 50
Has anyone managed to make a switch just like the OP but that would allow the sound system to play when ASD is disabled? I hate what ASD does in the highway (droning) but I really enjoy it when cruising at slower speeds.
For the moment, I simply pull off the switch when going for longer runs on the highway, but (of course) I would ideally like to keep the sound system working also... |
09-13-2018, 10:19 AM | #602 |
Rep 27
Just installed. As a few other posters mentioned, the rubber trunk seal is not necessary to remove!! I wasted a lot of time manhandling it back in place, only to realize I didn't have to remove it in the first place. Otherwise the install is a piece of cake.
The car sounds amazing in its natural, 'organic' state. The induction, engine growl, and exhaust flow together so nicely indeed. Why did anyone at BMW think the ASD would be a good idea? To hide the road noise I suppose? Who cares.. just install this harness and be happy. |
09-20-2018, 11:57 AM | #604 |
Rep 50
Thanks to the OP: I did just like you explained and now I have a switch that allows me to “remove” the fuse without having to go in the trunk.
It is therefore extremely easy to toggle between ASD on and off while driving and hear the difference live (audio memory is usually very imprecise...) I must say the difference in sound is MUCH less than what I thought. To me, the difference is only obvious when cruising on a highway at a constant 118 km/h. The droning really disappears when ASD is turned off. I will try to test the difference with my SPL onboard soon, but I suspect the SPL meter will not be able to record a difference because it seems so small subjectively. |
09-20-2018, 01:19 PM | #605 | |
Rep 1,608
Boostm3
09-23-2018, 08:09 PM | #606 | |
Rep 50
In every situation, I could this time easily hear the added noise when turning on the ASD. In every situation, the SPL meter was 2 (two) decibels higher with the ASD on. The baseline noise level varied a lot, mainly because of the various roads conditions I have tested (between 82 and 90 decibels), but every time I turned on the ASD on, the SPL meter went 2 decibels higher. Every time. That is significant, and easily audible (about 1.2 times louder), but still, that is not a lot more. But those two additional decibels are so annoying...! |
10-05-2018, 08:04 AM | #607 |
Rep 53
sup guys.. got my my18 and i've always coded out asd on previous cars.. my question is can i code out asd like all other fxx series or do i need some special hardware harness? thx
10-05-2018, 10:10 AM | #608 |
Rep 6,981
10-05-2018, 03:05 PM | #609 |
Rep 399
Drives: 2017 BMW M2 6MT
coded mine out with bimmercode and haven't looked back!
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
10-08-2018, 08:27 PM | #611 |
Rep 4,554
Drives: 2015 328d xDrive
I liked the ASD so much I coded it out AND installed a bypass harness as a double fuck you. Good riddance.
10-08-2018, 09:08 PM | #612 |
Rep 1,608
LOL>. I like that...Like double locking your doors
Boostm3
10-09-2018, 02:47 AM | #613 |
General Moron
249
Rep 158
Bypassing ASD has been one of the best (and cheapest) mods I've done to the car. It was horribly intrusive and completely unnecessary. Good riddance.
JB330Ci55.00 particulardude380.00 |
10-09-2018, 02:06 PM | #614 |
Rep 53
hey guys.. i've disabled asd on every bimmer i've ever had.. on my m2 lci i have the CAFD file changed but i haven't gone outside to load the file on car..
before i do that .. are the parameters for OFF the same as other Fxx? f20/f21 with the S63 engine? thanks |
10-11-2018, 01:03 PM | #615 |
Rep 50
I just installed the bypass harness yesterday. 30 minutes is all it took me. And yes, no need to remove the rubber seal.
As I reported in another thread, https://f87.bimmerpost.com/forums/sh...5&postcount=20 I did measure the difference in dB from my seating position and no matter the mode (sports or sports plus) or the MPE valve setting (opened or closed) I measured a consistent +2 decibels with MPE enabled. So, that is not +6 decibels as some have suggested, but those two extra decibels were annoying (droning is gone now on the highway). Last edited by Stef; 10-11-2018 at 01:38 PM.. |
10-11-2018, 01:04 PM | #616 | |
Rep 1,608
