09-07-2023, 09:53 PM | #485 | |
Rep 7,539
09-08-2023, 05:10 PM | #486 |
Rep 598
I'd like to learn more about it. Can you share or point me to a good source?
09-08-2023, 06:34 PM | #487 |
Rep 3,715
M2guru
I pulled up what I think are two representative logs for you on the same track with similar ambient, pre & post the CSF to do88 oil cooler change and I’m not seeing much of a difference. Similar peaks and similar deltas bn ambient, coolant, and oil. Altho, maybe I didn’t find a good comparison. Could you please post two logs so the group can compare? I do think the do88 is better from my logs, but it could be that you need to get back on the long version of your track to actually see a difference. |
09-08-2023, 06:38 PM | #488 | |
Rep 7,539
Then a year or so ago ZM2 and I brain stormed on how to get more cooling performance out of the m2, and one of the things we thought about doing was an m235i aux water pump retrofit. Upon researching I found out that the m235i aux water pump was DME controlled, and this could not be easily enabled via coding on the m2 - I could wire it in VIA the diagrams on ISTA but it wouldn't do anything. No coder on the forum could enable it either. So we decided to use the same pump tyspeed used which was an e39 aux water pump which is a simple on off water pump, when you give it power it turns on and runs full speed. So you just wire this to the ignition and make custom hosing and tuck it in the engine bay. Fast forward a few months later I found an aux water pump controller online that can control pierburg water pumps: https://tecomotive.com/en/products/tinycwa.html This thing is a fully independent pump controller, manual PWM speed control, or thermostat controlled and full on off capabilities at the user's request. This means you can use the m235i aux water pump and all of the m235i's hoses and brackets for an oem install. Fast forward a year or so and I am talking to Enabled and he is going through the BMW FR for me because I had a question on if the m235i aux water pump retrofit was possible and he finds out you can actually fully "retrofit" the m235i's aux water pump control logic into the m2 via an ECU tune. This means you can 100% retrofit the m235i aux water pump in an OEM fashion, and it will function like OEM too. So there unfortunately is no documentation on this no threads nothing. You will be the first one to do this. The only guides you will have is REAL OEM, ISTA, Enabled if you choose to do the tuning route, and the m235i for reference. This is what ZM2 and I have been doing for the last few years and what to expect when you're pioneering a field.
09-10-2023, 07:16 AM | #489 | |
Rep 598
09-10-2023, 07:18 AM | #490 | |
Rep 598
09-10-2023, 11:03 AM | #491 | ||
Rep 4,216
Edit: I went back and reviewed both threads and I see the logs you're comparing and this is not the correct conclusion: Quote:
His most recent run, he gets to 248F Oil after 14 mins, and coolant never goes above 227F - the remainder of the event, it's on or around 225F Last edited by AmuroRay; 09-10-2023 at 02:02 PM.. |
09-10-2023, 03:32 PM | #492 | |
Rep 7,539
ZM2 can provide the data, he's the only one that has done it so far.
M2guru425.50 |
09-10-2023, 06:09 PM | #493 | |
Rep 3,715
I think the do88 cooler is helping in my logs, but it’s inconclusive in M2guru logs. His oil and coolant temps have been fine all along on his short track and the cooler switch didn’t really impact that much in his logs. Until he switches IC’s so that power isn’t being pulled, runs on a hotter day, runs his long track with higher top speeds, and/or runs a hotter map (after IC swap), we won’t see the full impact of the do88 cooler with his setup. Last edited by ZM2; 09-10-2023 at 06:14 PM.. |
09-10-2023, 07:24 PM | #494 | |
Rep 4,216
I didn’t check, but ai though his maximum speeds were higher on his most recent run too. Not sure if I agree that more timing is going to measurably increase oil temps, especially for people who run e85 blends, which lower cylinder temps |
09-10-2023, 08:03 PM | #495 | |
Rep 3,715
Top speeds are the same, and if anything he was driving harder in the CSF log that also had a 7F higher ambient temperature and no let up after lap four. I’m not doubting that the do88 oil cooler is better, as evidenced in my logs and the fact that it takes a couple laps longer in M2guru sessions for temps to be the same between the CSF and the do88, but there’s no appreciable difference in peak engine temps after 8 laps which is where the focus should be instead of a few beginning laps of lower temps that have zero impact on performance compared to peak temps if they get too high. And, of course more power is going to require more cooling when temps are similar. That’s thermo 101 considering how thermally inefficient ICE motors are. My point is still the same, which is he’s not stressing the car hard enough to really show the improvement between the two oil coolers. If he had some long track logs in the summer with an IC that isn’t causing power to be pulled, then we would potentially see a real difference in his case. CSF followed by do88: |
09-11-2023, 09:35 AM | #496 | ||||||
Rep 4,216
I recorded 126.9mph, 125.4mph, and 125.7mph vs 127.7mph, 127.7mph and 128.9mph - this is literally consistent as he does it again on the second half of the log at the 21min and 22min mark. Quote:
Again, it's obvious it's working because the cooling system as a whole ran cooler: MIN MARKER| COOLANT (F)| OIL (F)| Post DO88 COOLANT (F)| Post DO88 OIL (F) 2 | 207F|233F | 206F| 224F| 3 | 219F| 237F | 200F | 224F 4 | 216F| 240F | 206F | 227F 5 | 216F| 237F | 6 | 219F| 239F | 206F | 230F 7 | 223F| 242F | 215F | 236F 8 | 225F| 244F | 223F | 242F Quote:
From my observations, it's abundantly clear his car is running better - as proved by his higher trap speeds. And it's running cooler, as evidenced by his lower recorded temps on both oil AND coolant (which indicates more oil cooler efficiency). The best part was they stayed consistently "low" through the whole day, which is exactly what anyone would want. For his use and most everyone else who isn't you, I would say a change to the oil cooler (and) the oil thermostat with Max Cool on the coolant would be more than enough for to handle any track day. The disconnect here is your usage =/= everyone else. If you want to stay in a "safe range" you're going to need a second oil cooler (in place of the aux radiator) and remove the coolant/oil exchanger. Or just live with being at the edge of temps. But most people aren't trying to push near 500WHP from a stage 1.5 turbo, so they aren't going to run into the same issue as you. Edit: Quote:
Mods: Yes.
09-11-2023, 12:17 PM | #497 |
Rep 607
To be fair to ZM2 the thread was created to help facilitate convo on what would solve HIS issues despite it evolving from there.
While you’re correct his requirements are fairly unique, it’s clear the DO88 cooler isn’t the end of the road for him. My opinion is that without a larger turbo delivering a cooler charge, and some other options that aren’t on the table like additional hood venting and thermal management solutions like I shared at the end of the prior page the goal won’t be met. (www.headershield.com) I am hopeful however that a D088 cooling pack will be enough for ~430whp running 20-25mins on a track that doesn’t use 5th gear. |
09-11-2023, 12:31 PM | #498 | |
Rep 4,216
He needs a larger turbo OR to get serious about the cooling system and go to a dual core oil cooler. It's never been about the coolant - they keep on talking about coolant temps, but the DO88 oil cooler shows that having a functioning oil cooler means the coolant system (which is tied in through the exchanger) doesn't have to work as hard. You're not gaining anything reasonable with the coolant pump, or another radiator, etc - I'm betting the M2 forgoes it to remove additional pumping losses, and made up for it with a slightly larger oil cooler.
Mods: Yes.
09-11-2023, 12:44 PM | #499 |
Rep 7,539
And yet tyspeed with his massive csf boss oil cooler + heat exchanger delete still couldn't keep coolant temps under control. Even with his race core radiator. To keep things under control he had to add a radiator water sprayer + water injection.
09-11-2023, 01:28 PM | #500 |
Rep 4,216
Not surprising considering the CSF radiator is worse than stock.
Mods: Yes.
09-11-2023, 02:49 PM | #501 | |
Rep 7,539
I've seen the same behavior on the n54 too, it's always coolant temps that go out of control
09-11-2023, 03:01 PM | #502 | |
Rep 4,216
They use the CSF core because it's absolutely larger than the stock one. On the F series cars, the CSF is a downgrade. I've seen 2 people on this side of the forum install them and immediately have cooling issues.
Mods: Yes.
09-11-2023, 06:03 PM | #503 |
Rep 3,715
AmuroRay I’ll go back to what I’ve said many times. M2guru coolant and oil temps have been fine all along. The switch to the do88 didn’t gain him any performance advantage on his latest track day.
Temps that are a little lower but still in the operating range have no performance benefit. The benefit only comes when coolant or oil temps get to power pulling levels. We have no idea if the do88 would help prevent that for him bc he’s not stressing his car enough (not a bad thing). Once he moves to a faster track, warmer days, a larger IC, and a hotter map, that’s when the cooling upgrades will actually be helpful or needed. For now, there’s no performance benefit for him with slightly cooler engine temps that were already within a perfectly acceptable range. The do88 cooler and BMS valve has helped my setup, but still need to dig further. |
F87source7365.50 |
09-11-2023, 06:19 PM | #504 |
Rep 7,539
M2guru what ots map are running?
