06-12-2023, 09:20 PM | #23 | |
Rep 7,543
Take a look at the crank bolt capture guys, they use grade 12.9 hardware and there hasn't been a single reported case of a bolt snapping due to embrittlement. Most of the hex bolts vtt sell with their parts are grade 12.9, and again no reported issue of embrittlement. So for track use where parts are frequently replaced, and strength is everything, if you use quality grade 12.9 hardware it's not going to be an issue.
06-13-2023, 02:13 AM | #24 | |
Rep 1,405
06-13-2023, 02:22 AM | #25 |
Rep 7,543
Not as common as in grade 12.9, but it can occur in grade 10.9. It can affect titanium too.
06-13-2023, 04:53 AM | #26 | |
Rep 436
Drives: F87 M2 DCT, F15 X5
06-13-2023, 06:05 AM | #27 | |
Rep 1,405
06-13-2023, 06:21 AM | #28 |
Rep 436
It’s such a problem that OEMs avoid them, it rarely gets brought up in engineering to use a 12.9 because it’s so frowned upon as a design solution. At a minimum do not use in anything safety or structural. Having worked on powertrain OEM projects, there is design checklists that ask if 12.9 or modified spec is being used and the team has to justify how every other option was explored and why it is acceptable. If 12.9 is implemented correctly with the right coatings and heat treat specs and quality control, it is effective.
Motorsport Hardware is not an OEM with a century of experience and millions of vehicles sold. Its an independent aftermarket supplier trying to sell you some race car parts lol. I don’t trust they are doing anything to ensure HE risk is minimized.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
06-13-2023, 07:18 AM | #29 | |
Rep 1,405
Vag 1.9tdi engines from 90hp to 130hp version use 10.9 head bolts, 150/160hp versions use 12.9 bolts. Bmw Motorsport knows what it is doing, for this reason they have studs that cost more than a CSR rim. Last edited by Track/S; 06-13-2023 at 07:25 AM.. |
06-13-2023, 08:20 AM | #30 |
Rep 436
Just for fun, I googled “hydrogen embrittlement NHTSA recall.” Here is a good one. There are many. 12.9 is certainly possible and useful when done right. But the “off the shelf” spec still offers HE risk.
https://static.nhtsa.gov/odi/rcl/201...9V039-4268.PDF https://static.nhtsa.gov/odi/rcl/201...5V347-4420.pdf |
06-13-2023, 10:55 AM | #31 | |
Rep 7,543
06-13-2023, 11:40 AM | #32 | |
Rep 7,543
Btw you don't have to be an OEM with "centuries" of experience to make good products, you can have after market companies make parts that are even better than oem, and just because a product is made by an OEM doesn't guarantee quality. For instance verus engineering makes way better aero parts than even Porsche's factory OEM parts, why? Because they don't have any restrictions stopping them from doing so. Then look at bmw, look how good their OEM charge pipes are.
06-13-2023, 01:44 PM | #33 | ||
Rep 1,405
Totally agree, |
06-13-2023, 02:04 PM | #34 |
Rep 7,543
Keep us posted!
06-13-2023, 02:16 PM | #35 |
Rep 436
interested to hear the results! Can you share the process for measuring the HRC as well? Sectioning the bolt, and were the measurement on the cross section is being taken. Do top and bottom cross section too. Are you able to check alloy element % as well?
06-13-2023, 02:49 PM | #36 | |
Rep 1,405
12.9 bolt For alloy element % we send to an external laboratory. |
06-13-2023, 06:07 PM | #37 |
Rep 436
Isn’t a 12.9 bolt 39-44 HRC per ISO 898? Not sure exactly where ISO 898 specifies the measurement. Perhaps section just under the head of the bolt and measure half way between the center and OD on the transverse plane. Take 4 measurements, 90 degrees apart. Might as well do the center core too. You might be measuring the carburization (or decarb) layer on the OD.
06-14-2023, 01:56 AM | #38 | |
Rep 1,405
06-14-2023, 05:50 AM | #39 |
Rep 436
The OD leaves a lot of risk to being fooled by coatings, carbon layer from forming, ect. This is already evident because the 12.9 bolt you measured is below 39 HRC. I’d really like to learn why the CS-R studs would have a DLC. Seems strange to put a coating that specifically reduces contact wear on the threads… If you have the extra time, I’m sure the M2 community would really like to see the transverse section measurements
06-14-2023, 08:46 AM | #40 | |
3039
Rep 13,778
~loud noises~
E90convert182.00 |
06-14-2023, 01:50 PM | #41 | ||
Rep 1,405
When csr stud arrives I will test a 12.9 bolt from another brand. Quote:
UK is outside the euro zone, they must pay customs on everything they import from the EU. |
06-14-2023, 05:12 PM | #42 |
Rep 2,882
Not to dampen the engineering debate, but all of this is somewhat missing the point - the screw in stud has inherent flaws, 10.9 or 12.9. The frequent use of these type of studs amazes me, given their failure rate - I know it makes for an easier wheel swap, but not worth the risk (I can take the extra 2 minutes to use screw-in guide studs for mounting wheels - I'm not timing my pit stops). If you are going to run these, please remember they are race parts, with a rather short duty cycle before replacement (ask the BMW.
It also sidesteps the fact that there are limitations to effective clamping force that are far more problematic than the ultimate fastener strength (a bolt tht isn't properly torqued is already half broken, and there are a host of issues that compromise the effectiveness of torquing lugs). CORE motorsports has some good discussion, and they are good with Q&A for you techhies. If I get any more serious about tracking, I'm going to have them make me a set of hubs (about 650-700/hub, IIRC). I believe CORE sells 12.9 studs (ARP or MSI) with these kits, and matching nuts. https://www.core4motorsports.com/tech Here is an excerpt from my communications with them: From and engineering stand point, going to a grade 12.9 for a wheel bolt isn't justified. Need to keep in mind the material you're screwing into (hub), which is typically far from the strength of a grade 12.9 fastener. It's the equivalent of using mis-matched screws and nuts. If (and that's a big if) a grade 12.9 bolt is to be tightened to the level that they should theoretically be tightened to, there's an increased risk of deforming the threads in the hub, or worse, stripping them since the capacity of the bolt is much greater. So in essence, the benefit of a grade 12.9 fastener is the ability to be able to clamp the parts more tightly. If that can't be done, what's the point? Answer: there is none. This is where there's another advantage of a press-in style stud since you don't rely on the hub material to generate clamping/tension if you want to move to a higher grade fastener. You just get the correct grade lug nuts. My first recommendation would be to stick to the OEM wheel bolt or equivalent grade 10.9 and just make sure you keep track of the cone seat of the bolt to be sure that no galling is occurring from the aluminum wheel to the lug nut. My next recommendation would be to use a wheel bolt that has a floating conical washer, like these: https://www.bimmerworld.com/Wheels-T...3-X5-19mm.html In my torque/tension testing, I found this floating-washer style not only gets the clamping closer to the ideal value, it does so very consistently after many tightening/loosening cycles because it prevents aluminum from the wheel galling onto the cone set of the bolt/nut. You will see many OEM vehicles and trucks starting from early 2000's onward that have this floating style concept. There's a reason for it. If you haven't read our tech pages which goes more into galling, etc. see here: https://www.core4motorsports.com/tech |
E90convert182.00 F87source7368.50 |
06-14-2023, 08:33 PM | #43 |
Rep 436
Maynard these are really good points. Ironic you dampen our materials engineering debate and bring in fastener engineering 101! I 100% agree with the points you made. I suspect the hub is hardened steel given that the thread engagement looks to be about 1.0x the thread diameter. Moving to a stiffer 12.9 might make stud fatigue more problematic based on bolted joint stiffness diagrams. However a 10.9 tightened to factory spec with racing slicks end up slipping the joint and causing loosening. I’ve not heard of that happening so I suspect the clamp is adequate.
The collared fasteners were factory on my Cayman. I thought the design was unique, and in the manual you had to grease the threads and flange to collar face with a very specific grease type. I suspected this was to give a consistent friction coefficient for more consistent clamp. Question: do you think the stud and nut eliminates a failure mode of the bolt fracturing at the ball to shank transition? Or would the transition be smooth enough that the notch factor is basically doesn’t matter. Anyone know the tightening torque of a CS-R wheel nut?
‘18 F87 M2 DCT
Maynard3861.50 |
06-15-2023, 01:17 AM | #44 | |
Rep 7,543
But the goal of using stronger bolts such as grade 12.9 bolts was to try and prevent snapping (not due to the common reasons that studs fail on this platform, but compared to weaker/light weight bolts such as titanium - which has a very high strength to weight ratio, but for a fixed size object where the weight of titanium is going to be significantly lower than steel, the out right tensile strength ends up lower. For example: aluminium has a way higher tensile strength to weight ratio than steel at 99 vs 63. But when the object's size is fixed like alumium vs. steel bolts, the steel bolt will be way stronger. The only time the alumium bolt is stronger is when it is equal in weight, but that leads to a bolt that is way bigger and in the case of wheel bolts we are limited to a fixed size - M14 threads iirc.), not to try and increase clamping loads.
Maynard3861.50 |
