10-07-2020, 03:35 AM | #23 | |
Rep 557
When I installed my Ohlins R&T I adjusted the shock length with the spring out so I could have max compression with the tyre not contacting wheel arch lining (at the time I had 285/35 PS4s), measuring from the bottom lip of 437M to top lip of guard was 545mm (car weight on Ohlins shock bump stop), full droop in this setting is 675mm. Looking at my notes I think the shock length was 510mm (where the instructions say 500), I'm just not 100% I recorded the shock length accurately Just for interests sake the oem shock/bump stop allowed 15mm less compression travel, I was after more as on our bad country roads it wasn't uncommon to bottom out badly and the rebound was very unsettling. I believe pre-load just determines ride height and I varied from the instructions as I didn't want the full 10mm drop from oem (& my rear springs at 160Nm), unfortunately I didn't write down my pre-load but I'm lowered around 6mm. |
10-12-2020, 06:43 AM | #24 | |
Rep 76
Then set the car down, drove around the block to get the suspension to settle and put the car on the 4 post lift. The rear shock that is provided by Ohlins has 99mm travel. They wanted to see 55% compression travel, 45% droop travel. This is fairly easy to set if you have a 4 post lift. With the car on the 4 post lift, I measured the rod length which is showing while the car is sitting still, which gives you the compression travel. remember you need to measure including the bump stop. If you need to make adjustments to the shock height, every turn is 1.5mm in length. Once I made the adjustments, again drove around the block to let the suspension settle, came back put the car on the 4 post lift and measured again. I am currently at %54 compression to 46% droop, which is close enough. |
David.m449.00 |
10-12-2020, 12:47 PM | #26 |
Rep 76
Just uploaded the video from yesterday, the track condition wasn't that good since three corners were compromised because of puddles, but the car is behaving much better in the video.
Connors5453469.50 |
10-12-2020, 04:49 PM | #27 | |
4779
Rep 2,571
Were you able to run about the same pace between those two sessions you are referencing even with the wet & dry conditions? Are you set up to run telemetry?
10-12-2020, 05:50 PM | #28 | |
Rep 76
Running telemetry from OBD2 right now, which has not the greatest sampling rates. I will eventually hard wire the CANBUS cable. The first video I posted on there wasn't too bad, even though most people get scared with a little bit of a drizzle, the track has a lot of heat and grip even with the light drizzle. I think the conditions were more favorable the first time I was out while the car was having the corner exit issues. Lap times were very comparable, however as you can see from both videos, with the new setup I wasn't pushing crazy since 3 of the corners were compromised due to standing water. If I can make it out this week, I will definitely be back to see if I can put down some hot laps with the track fully dry. But all this rain we are getting isn't really helping to keep rubber on the track to keep it fast. Last edited by iBrakeLate; 10-19-2020 at 04:16 PM.. |
10-17-2020, 11:10 AM | #29 |
Rep 76
More updates on this, with the new settings that Ohlins recommended the car is a bit better but as the tires wear, still running into similar issues, just not as bad. After spending another day at the track trying to get a feel as to what is going on and what to do, I was lucky enough to have a pro driver who has a lot of experience give me his thoughts.
The main issue he noted is that the spring rates that Ohlins supplies with this kit is way too stiff, 90N/mm front (~513 lbs/in) and 190 N/mm rear ( ~1084 lbs/in). Just ordered 70N/mm front (~399.71 lbs/in) and 120 N/mm (685.21 lbs/in) springs. Also will be switching up the tires too, the A052's sidewalls are too soft, going to try the Nankang AR1's. I will update this thread once I have some more information, might be useful for those who track their M2C and want to have an idea of a better setup to run than out of the box stuff Ohlins offers. |
10-17-2020, 08:03 PM | #30 | |
Rep 427
I’ll be interested to hear how those rates work for you though. I know TC Kline recommends significantly softer rates with his coilovers. Maybe I’m thinking about this wrong. |
10-19-2020, 12:15 AM | #31 | |
Rep 76
I get tire rub in the back on very very big bumps/dips in a construction zone. On track it is no where near getting to that level of compression travel. |
10-19-2020, 09:55 AM | #32 | |
Rep 427
I might be able to address by stiffening the shocks (running 11 clicks from full firm all around for our bumpy tracks), but current setting works well everywhere else. Probably still something I should experiment with. The current tires really had me focused on it as they’re a bit taller than what I was running before. If softer springs with stiffer damping will control travel better, I’ll be interested in hearing so. As I said, I may be looking at how to address all wrong, so please do let us know. |
10-19-2020, 04:19 PM | #33 | |
Rep 76
I run a taller tire in the rear (295/35/18) and ride a lot of the curbs on the track and haven't had any issues with the suspension bottoming out / hitting the bump stops. I even ran the rear shocks at 20 clicks soft to test and still didn't get to the bump stops on track. |
bentom2335.50 |
10-19-2020, 04:54 PM | #34 | |
Rep 427
10-20-2020, 09:15 AM | #35 |
4779
Rep 2,571
iBrakeLate - do you run this PBIR setup on other tracks? And have you tried a more uniform setup at PBIR? Something that can be used to rule out that the setup for some reason isn't playing nice with the car/suspension?
In the short video where you brake loose on the right turn exit of either 4, 5, or 6 (depending on which map you are looking at ) - does the track transition to off camber at that point? I can't exactly remember - but do think that you at least lose some banking in the track right there? Can you possibly overlay the throttle telemetry on the videos? Not saying that is what happened - but could be useful just to rule out it was throttle related. It doesn't sound like it in the video, but sometimes video & audio might not sync perfectly.
10-20-2020, 09:55 AM | #36 |
Rep 379
I have had Ohlins R&T on my 335is, they are great! Your "damping" settings sound like it is too soft, IMO. I don't know how bumpy the track is though, still feel the setting is too soft. Also, the R&T are all set at 7 - on all four corners, by default. It looks as if you might be treating the rear setting as a "2-way", taking out in order reduce rebound? Look at how soft you made the rear? The single-way adjustable coilovers need to be treated more equally on all four corners, I feel. As a starting point, I would try something like - Front 5 and Rear 6. That will definitely stiffen things up and make the rear much more solid! I got to the point with my Ohlins R&T that I was running 2 from max both front and rear on flat tracks in my 335is.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 Last edited by M2joey; 10-20-2020 at 10:01 AM.. |
10-20-2020, 11:13 AM | #37 | |
Rep 76
Track doesn't go off camber. Also this isn't just an issue with that corner, it just is more noticeable there as it is a longer sweeping corner. Just received my softer springs, hopefully this solves the issue. If not, I will be removing the Ohlins from the car. Again this is an issue only if the car is being really pushed to the limit of grip. If you drive it at 8/10s you don't notice it. |
10-20-2020, 11:18 AM | #38 | |
Rep 76
I've tried 7 all around, 12 all round, and 20 in the rear with 12 in front. Nothing really helped hugely with this issue. The biggest change in positive handling characteristics was when the rear shock length was adjusted to the correct 55/45 compression to droop ratio. The car with these spring rates are so stiff that can't even touch a single curb on track, or the car literally gets thrown off the curbs. The last theory is that the setup is extremely over sprung. Which if you look around no other big name manufacturer provides their setup with such high spring rates. Going to install the new springs when I get a chance and give it a try again. |
10-20-2020, 12:08 PM | #39 | |
4779
Rep 2,571
Good luck with the springs
10-20-2020, 10:18 PM | #40 |
Rep 303
What alignment settings did you go with for the revised set-up ?
Have you looked onto some race (helm jointed) style toe-links ? I used the standard spring rates Ohlin supplies..no issues / problem on track. |
10-21-2020, 02:32 AM | #41 |
Rep 88
I would make sure they are within the valving range of your R&T... 70 in the front is probably OK, but going down to 120 from 190 will most likely be outside of the valving range. Speaking from personal experience, I also found the original R&T setup to be on the soft side as I tracked with the original setup for a year and decided to revalve them to 120/220. Regarding the rear sitting on the bumpstop, R&T is rebound biased so there isn't much compression damping to begin with, and the adjustments mostly account for the low-speed damper movements. I don't believe going with a much softer rear spring would alleviate this issue at all.
bentom2335.50 |
11-10-2020, 04:05 AM | #42 |
Rep 96
How old are your tires? I suggest you try with a set of tires that arent heat cycled.
I run into that problem on my car Spring rate also will be drastically different with a true coilover if that is the benchmark you are comparing against. Ohlins is not a true coilover in the rear.
Currently Driving:
Porsche GT4 '20 BMW M2C '19 Caterham S3 '01 Porsche 993 '96 |
11-10-2020, 08:37 AM | #43 | |
Rep 379
Edit: I am also curious as to what you hot tire temps are after 5 laps? With RE71-Rs it seems your optimal grip arrives around lap 4 to 6, track, temp, etc. depending. You might want to remove 3 psi from the rear only as a test. Without knowing the hot temps though, maybe more, maybe less. For RE71s it seems 33-35 hot is best, very hard to keep them in that range unless is a cooler day.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 Last edited by M2joey; 11-10-2020 at 08:54 AM.. |
11-11-2020, 10:18 AM | #44 |
Dirt Junkie
116
Rep 76
Drives: 2020 BMW M2 Competition
Subscribed!
I'd swear that video was out of my cockpit. I have EXACTLY the same issue. I got my car out this weekend (Inde Motorsports Ranch in Willcox, AZ - new pavement, FUN track) for the first time since getting all the suspension installed and set up. Present setup: 9.5 & 10.5 x 19 Apex EC-7 wheels Toyo R888R sneakers - 265 & 295 running 36-37 hot RSR cage Pagid Yellows (this is changing next round) Ground Control camber plates (noisy things) and Turner adjustable rear toe arms Ölins R&T suspension both front and rear are 10 clicks out (will play with these next round) Ride height is 8 mm lower than stock (supposed to be 10mm lower). There was an intentional reason for the higher setting that's been addressed (trailer setup). Car is set at 3 degrees camber, zero toe front 1.9 camber, presently mentally blank on toe in - 1 degree, I believe. Manners are fantastic right up to starting to add throttle after apex and the back end gets twitchy, often leading to nice high speed drifting (can be fun, can make one's butt pucker). It's quite consistent left or right handers and as the OP stated, the faster, more open sweepers seem to be more problematic than the tighter stuff. I'll take the steps OP has as far as preload and ride height (I'm sitting too high - definitely in the rear) and see what happens next month at a smaller, tighter track (Wild Horse Pass - Bondurant course). I really hope I can dial it in w/o going to a softer spring rate. I do agree that they seem to be pretty stiff the way Öhlins sets them up. Other than this, the car is brilliant to drive on the track.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW-What a Ride!'" - Anonymous
