ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      10-16-2019, 06:51 AM   #23
Reborn_
Drives: 2007 BMW Z4MC
Thanks! I added your cable to the first post. As you play with some coding, please post back. I'd like to start building up post 3 of 3 with confirmed options.
      10-16-2019, 04:16 PM   #24
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
Originally Posted by BoarderPhreak View Post
Just out of curiosity... Anybody try/get this to work with Windows running on a Mac through, say, Parallels or Fusion? Or Linux?
I have it running on older gen MacBook Pro through VMware Fusion. Have done few tests and calibrations using DIS.
PS: Tried Parallels also but couldn't manage to boot it up correctly.
      11-01-2019, 02:51 PM   #25
CSM3
CSM3's Avatar
Drives: E86 Z4M, F80 M3CS
Just wanted to share an update from my recent experience:
1. This amazon cable works, there is a switch built in, set it all the way to the right. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2. Use the Bimmergeek Coding Tools, it did everything i needed, including a working "Manipulation" profile for NCS Expert. Works on mac with VMWare Fusion - Windows 10
3. Basically dug through numerous threads just to find out how to deactivate all amber light regardless off headlight switch position, and to only function as turn signals. Just wanted to throw this out here as there were so many combinations around. This worked for me.
ECU Module: LSZ.C36
PIN_20_37_ALS_PO = Set to nicht_aktiv
SL_VO_ANSTEUERUNG = Set to nicht_aktiv
SIDEMARKER_US = Set to nicht_aktiv
Also managed to do M Dynamic Mode with just one change:
ECU Module: MK60
TDR = Set to Aktiv
Did a couple more, but the guide to them is easily available. Happy to share any specific ones if you reach out.
At the same time, i am still figuring out the following:
AMP Setting, Mirror Tilt in Reverse, Auto Unlock Doors when the engine is shut off.
If anyone has had success, please share!
Thanks OP for creating this thread.
Mandatory pic for being almost eggless! ��
Reborn_298.00
      11-01-2019, 04:36 PM   #26
Reborn_
ECU Module: LSZ.C36
ECU Module: MK60
TDR = Set to Aktiv
Details added to the appropriate posts (1-3). Thank you for sharing!
The ones you listed, are you asking for help with those? I'd also like help for auto unlock doors when engine is shut off, and even lock doors automatically (haven't gotten that to work).
      11-01-2019, 04:40 PM   #27
CSM3
CSM3's Avatar
1. This amazon cable works, there is a switch built in, set it all the way to the right. https://www.amazon.com/gp/product/B0...UTF8&psc=1
ECU Module: LSZ.C36
ECU Module: MK60
TDR = Set to Aktiv
ECU Module: LSZ.C36
ECU Module: MK60
TDR = Set to Aktiv
Yes sorry I am not sure why that phrase asking for help went missing. I haven't been able to do those listed.
I can definitely help with auto lock. Basically you also need to code the key memory to auto lock. Will respond here with the specific modules shortly!
Thanks again for getting this started OP!
      11-01-2019, 07:09 PM   #28
Reborn_
A ha! I think I know all the modules, but would be good for you to corroborate. Could you also add how to code the key memory as well? I think that's the part I'm missing!
      11-01-2019, 09:15 PM   #29
CSM3
CSM3's Avatar
Auto Lock after "X" MPH.
Module: GM5.C05
VERRIEGELN_AUT_AB_X_KMH: Select the speed you would like auto lock to happen
VERRIEGELN_XKM/H_SENDER 1: Select the option to auto lock, and do the same for Sender 2, 3 and 4. Basically this is the coding to tell the key to allow autolocking based on all the keys you might use to start/unlock your car.
VERRIEGELUNGSSCHWELLE: Set to Aktiv
      11-01-2019, 09:27 PM   #30
CSM3
CSM3's Avatar
Couple more options i did:
1. One Click Unlock all Doors with remote:
Module: GM5.C05
Setting 1: FUNKTIONTUERSCHLOSS: Select the option for all doors
Setting 2: FERNBEDIENUNG_1: This is the memory setting of your car key, there are four of these, FERNBEDIENUNG 1, 2,3 and 4. All should be set to the option of all doors unlock.
2. Wipers complete cycle (When you shut off the engine, the wipers will complete their cycle and not just stop halfway on the windshield)
Module: GM5.C05
Setting: WISCHER_VOLLEND_KLR_AUS: Set to Aktiv
3. One touch indicators:
Module GM5.C05
Setting: CYCL_TI_BLK: Select 3
      11-10-2019, 06:38 PM   #31
bwright657
bwright657's Avatar
258
Drives: 08 Z4 M Coupe
Great guide Reborn_!
I got the cable with the built-in switch and it worked fine.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
      11-30-2019, 03:50 PM   #32
bwright657
bwright657's Avatar
258
If you upgrade your DRL angel eyes to LED, here's how you can disable warning lights.
1. Disable bulb monitor for Angel Eye DRL bulbs:
Module: LSZ
Setting 1: WARMUEBERWACHUNG_FL - HOT MONITORING OF HIGH BEAMS set to nicht_aktiv - not enabled
Setting 2: KALTUEBERWACHUNG_FL - COLD MONITORING OF HIGH BEAMS set to nicht_aktiv - not enabled
Last edited by bwright657; 05-28-2020 at 02:22 PM.. Reason: Correct module for coding
      12-10-2019, 01:51 PM   #33
Terraphantm
Drives: E46 M3 Coupe
Originally Posted by GuidoK View Post
You can just buy an el cheapo aliexpress/ebay cable for about $12 shipping included and save yourself 25 bucks
https://www.aliexpress.com/item/32975072256.html
Buy the one with the switch. Switch to one side for kkl (e85 chassis) and the other side for d-can (e89 etc)
Further more its not important to set the com port to com 1.
Just make sure that you set it to the same com port as in the obd.ini (in the ediabas bin directory). It can be any com number.
set the latency to 1 and the bps to the highest value.
For D-CAN cars it's worth getting the bimmergeeks cable. The default firmware on these cables have a firmware bug that causes some modules to brick. For the E85/6, it doesn't matter since it uses the K-bus anyway. You can flash the firmware yourself, but it's a bit of a pain since most of these cables don't have test points to reprogram the atmel chip.
      01-23-2020, 12:44 AM   #34
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Well thanks reborn_ ! Going to attempt some of these coding soon!
      04-14-2020, 09:39 AM   #35
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
I have a Carly which has been great to add some extra features, but I've really got to give this a go one day. There are things I want to do which Carly doesn't have the functionality for, such as turning off all the bloody amber lights on the front when the lights are on.
      04-14-2020, 11:34 AM   #36
tominizer
tominizer's Avatar
99
Drives: 2007 Z4M Roadster
Sucks that none of the cable links are available right now. Either the link is dead or the item is NLA
      05-05-2020, 12:26 PM   #37
Cyclops
Cyclops's Avatar
1474
Drives: 09 E91 328i & 07 E86 M
Module: GM5.C05
Wrong module, it's actually located in LSZ
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter
      05-08-2020, 12:14 PM   #38
g2096
Drives: IS300
I purchased this cable with the software https://www.ebay.com/itm/BMW-DIS-V44....c100005.m1851 for my 2008 3.0si and connects and works with everything with no issues. If you're just looking for the cable only there's also this https://www.ebay.com/p/2231463508?ii...oaAlf1EALw_wcB Here's a tutorial that helped me to with using NCSExpert and NCSDummy https://www.youtube.com/watch?v=p9QizWwtI-g . If you need any help with anything feel free to pm me.
Also here's a video that shows the switch positions on the USB cables that have the switch. https://www.youtube.com/watch?v=VBW4vP41Qyc
My Z4 will only fully connect in switch position K
      05-08-2020, 12:23 PM   #39
yyz_bobby
Drives: BMW Z4 (2007)
Anyone managed to get ISTA-D working okay?
      05-13-2020, 11:06 AM   #40
FigureItOut
Drives: BMW Z4 3.0i
Has anyone figured out how to disable or otherwise bypass issues with the secondary air pump and secondary 02 sensors? I'd like to drop my SAP and get rid of the code for my headers.
      05-13-2020, 01:34 PM   #41
yyz_bobby
I got ISTA-D working and deleted transport mode.
I will be making some videos on it and hoping to post on all forums to help.
      05-16-2020, 02:35 PM   #42
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
I have ista-d working on my F25 (ethernet obd interface), but have not tried it on my E86 (dcan obd interface). I assume I would need to change some settings. I have a old laptop set up with NCSexpert & inpa for my e86/e39 and a newer laptop set up with e-sys & ista-d for my F25.
What problem are you having?
      05-18-2020, 05:57 AM   #43
yyz_bobby
So I managed to get it working and deleted transport mode. took some tweaking of EDIABAS and ODB config file. Not sure if I changed the switch position on dcan cable.
being the nice guy I am i thought i would do a guide and video and therefore wiped my laptop to reinstall everything and DOH. Something not working.
I created a video and uploaded here:
https://www.dropbox.com/s/wud6dmd2yl...error.mkv?dl=0
      06-10-2020, 06:20 AM   #44
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Hand held scanner
Sooo looking to invest in a hand held scanner is the Foxwell unit a good all rounder to use. I see on the bimmergeeks they have one, ProTool is ir? but not for the E85 / E86 chassis. The cables etc coming from them and will download the software in the trusty laptop. But looking to acquire a hand held well, just 'cos we can.
Any and all advice taken on board, thanks for reading, Bill
zpost
