12-13-2018, 06:13 PM | #23 |
Rep 220
I keep coming back to these. Can I justify it based on the work I do? Probably not. But it would make the work I do that much easier and I'm not getting any younger, and it's a helluva lot safer than jury rigging jackstands, and....
Can someone explain what the 5000 comes with as far as the rubber blocks and if it's sufficient for the M2? I assume I'd want to get as much lift as possible to slide under to work on downpipe/other exhaust and of course I don't want to tater the plastic on the jack points. Other projects are an e90, R56 Mini, 66 Mustang and possibly a 2014 Acura RDX, but not so likely on the latter. Would I need to invest in any other components to work on any of these? |
M3 Adjuster7909.00 CrashFL137.50 |
12-13-2018, 06:29 PM | #24 | |
Rep 3,549
For your other vehicles, check the jack point spacing. I have a feeling with the RDX (and possibly Mustang) you'll need the frame extension kit if you get the 5000SLX. I need those to reach the jack points fully on the latest Accord. Of course, if you get the 5000EXT you won't need that. |
12-14-2018, 01:26 AM | #25 | ||
Rep 1,466
One last thing that I ordered, and which isn't on their website, is some square cupped top plates for the SUV and Light Truck adaptor set which you use as an alternative to the round flat top plates that are supplied as standard with that accessory. I found that the Honda bent over pinch weld jack points were un-safe on just the rubber blocks, especially if you don't have the whole of the rubber block under the jack point because the spacing is too far without the frame extensions! The square top plates solve this problem because they've got rubber inside a square channel. Even if there were to be some slipping, the metal channel would prevent the jack point slipping entirely off. I'll try and tack some photos of these square top plates at some point and post here. You don't need jack pads for the square plastic jack points with a quickjack; the rubber blocks lift the car perfectly on this jack points and don't damage them at all. Just make sure the rubber blocks are centred on the jack points.
2018 ///M2 LCI, LBB, 6MT...
12-14-2018, 02:55 PM | #26 | |
Rep 3,402
Safety is the key for me. These modern cars are really only safe when being lifted at those 4 main lift points (a few exceptions exist) this is the safest, portable and affordable solution I have seen. For other cars the key is the distance of the lift points. I use mine for my M2 and my wife's Honda Accord, the Accord has a much longer wheel base but it works fine. For SUV most use the adapters that you can buy. |
12-14-2018, 05:41 PM | #27 |
Rep 243
BTW: Is the car cover (touches like all fabric) sold in Costco worth buying? It's for indoor, dust proof only.
2016 F87 M2 DCT LBB
12-16-2018, 11:40 AM | #28 | |
Rep 1,431
Question for those who have replaced their sport cat - is front end only ramps sufficient for completing the install? |
M3 Adjuster7909.00 |
12-16-2018, 07:37 PM | #30 | |
Rep 392
Dabozo635.00 |
12-16-2018, 08:11 PM | #31 |
Rep 3,402
Looks like they did not pay close attention to having the quick jack in the locked position. The right side jack is fully locked, no way the left side can go down unless it is unlocked. It is a hydraulic system which is why the car should never be left in the up position unless the locks are engaged. With the locks engaged they can hold far more than what they are rated for.
qnet684.50 |
12-16-2018, 11:02 PM | #32 | |
Rep 220
C'mon man, do it. I'll split it with you. We can keep it at my house but you can grab it whenever you need it |
12-17-2018, 04:23 PM | #33 | ||
Rep 1,431
Complicating matters is other than the cat I can't really think of a reason why I would need to work under the car. Most of the maintenance items (brakes etc) or mods I'm interested in can be achieved from the perimeter or above. There is however a damn garbage bag that I ran over in the spring and now I'm always greeted with the smell of burned plastic when I exit the car ...drives me nuts. I've scraped as much off the exhaust that I can reach but more remains So at this point, the lift would be more of a luxury than a necessity. But stay tuned...tomorrow is a new day I may change my mind again lol. What's Costco 's return policy? A year? Oh god.... |
12-18-2018, 02:47 PM | #34 | |
The deuce gets loose
290
Rep 499
Floor surface must be dry, flat, and have a minimum compressive strength of 500 PSI. Do not work under an elevated Vehicle unless properly rated Vehicle Jack Stands are used and place under the factory approved Lifting Points. Yes. If you put your QuickJack Frames next to each other with both Lock Bars on the outside and the end with the sticker away from you, then the Frame on the left is the “left” Frame and the Frame on the right is the “right” Frame. These are the orientations noted on the boxes the QuickJack Frames come in and is shown in the drawing in Unpacking. (so they used them backwards as well. left side of a car is driver...) Last edited by McPurrs; 12-18-2018 at 02:59 PM.. |
12-18-2018, 04:20 PM | #35 |
Rep 147
Wait. So for liability they tell you that you need to use jack stands in addition to the Quickjack? And those jack stands are supposed to go where the Quickjack lifted the car from? Uhhh....
12-18-2018, 04:43 PM | #36 | |
Rep 1,431
12-19-2018, 10:09 AM | #37 |
290
Rep 499
12-19-2018, 12:03 PM | #38 |
Rep 423
No, that is a generic safety quote. The quickjack is a properly rated jack stand.
12-19-2018, 12:56 PM | #39 |
290
Rep 499
12-19-2018, 05:45 PM | #40 |
Rep 423
Yes, I have the manual. My interpretation was quickjack = jack stands. However, I've been wrong before.
12-20-2018, 02:21 PM | #42 | |
290
Rep 499
How did you interpret that from this? : "Do not work under an elevated Vehicle unless properly rated Vehicle Jack Stands are used and place under the factory approved Lifting Points." Edit: but then I read this shit on their website: "No More Jack Stands! QuickJack offers far more surface area than jack stands, substantially increasing its stability compared to old-fashioned stands. The self-locking bars do the work of those stands—and everyone agrees, this portable car lift does it better." So I agree with another poster here, it is for legal purposes. Though I would think they would lose as they contradict themselves but I am not a lawyer. Last edited by McPurrs; 12-20-2018 at 02:29 PM.. |
12-20-2018, 03:10 PM | #43 |
Rep 423
I saw it as a generic safety quote and just used some common sense. The whole point of the quickjack is to replace a jack / jack stand system. I really didn't think it meant I needed jack stands too. Quickjack fits under the jackpoints and goes up like three feet. I haven't even seen jackstands that could go that high.
12-20-2018, 05:58 PM | #44 |
Rep 2,561
Drives: Rapidly from A to B
Actually less than 2 feet with the standard rubber blocks.
https://www.quickjack.com/car-lift-s...-car-lift.html |
