M2 Technical Topics > Suspension | Brakes | Chassis > Non OE rotor options
      05-01-2018, 12:25 AM   #23
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Anybody know if the M2 Competition's larger brakes use a different rotor setup?
I'm thinking that next year I will probably be due to change pads, and hopefully by then some of the 6pot + 4pot setups will be available lightly used or as new OE parts... but I'd rather use Girodisc rotors than the BMW stockers.
      05-01-2018, 12:26 AM   #24
pruettfan
Different diameter rotors so you would have to consider other options which might be slim for a while.
      05-01-2018, 12:31 AM   #25
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Yeah... and it looks like the larger rotors and calipers make 18" wheels impossible too. That's a non-starter for me since my winter setup is 18". So I guess I'll be moving to Girodisc eventually
      05-06-2018, 09:06 AM   #26
Twt
Twt's Avatar
635
Drives: 2017 M2
Stoptech has a a lot more fins....perfect bolt on :
tenkies148.00
      05-16-2018, 02:47 PM   #27
pruettfan
Over in the M3/M4 brakes section Golan at Auto Talent reported that Alcon has come out with both front and rear rotors for the M2/M3/M4. I pmed for pricing but haven't heard back yet. They look very nice.
      05-16-2018, 04:59 PM   #28
Franzino
Franzino's Avatar
Belgium
861
Drives: M2 MY17 / Alpine A110 MY19
https://f87.bimmerpost.com/forums/sh....php?t=1474106
      05-16-2018, 05:15 PM   #29
pruettfan
Originally Posted by Franzino View Post
Thanks, not sure how I managed to miss that thread.
      05-18-2018, 07:56 PM   #30
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Originally Posted by Twt View Post
I just received the Stoptech front two piece rotors from Turner. They look good and weigh 23/10 vs 25 for OE. I will install them this week and test them at Sebring in May. The fact that they claim 60% more air flow , are lighter and only slightly more expensive than OE appears to be a descent upgrade.
Attachment 1812367
An you share the cost of the rotors?
      05-19-2018, 06:03 AM   #31
Twt
Twt's Avatar
635
Drives: 2017 M2
Turner and others sell them for about 1k a set for rings and hats....thereafter you only need rings which are 650 a pair
      05-21-2018, 01:06 PM   #32
M Fifty
847
Drives: M2 & 330CI
So... hopefully you all realise the stock rotors are two-piece?
      05-21-2018, 01:17 PM   #33
pruettfan
We do, the concern is not the two piece issue alone, the oem hat is not reusable where aftermarket options are which if you track saves you money by just replacing the ring. Also most of us want to get away from drilled rotors as they have a tendency to crack sooner than slotted which is why you never see them on a modern race car, finally we are all looking for better cooling ie more vanes.
      05-21-2018, 01:45 PM   #34
M Fifty
847
Drives: M2 & 330CI
Surely more vanes means less airflow? More metal could be a good thing though.
      05-21-2018, 02:19 PM   #35
pruettfan
I’m not an expert but the folks at Essex are and they talk about both the number of vanes and the shape to help increase air flow. The oem are really a perfect match for the 98 percent that use their car on public roads and do some spirited driving, they are even fine for a fair amount of track driving but when they come up for replacement those that track are probably best served with one of the aftermarket options. On the road you might get 300 degree temps if you really brake hard and that is for a short period, on track this weekend my rotor temps were over 650 for 20 mins, of course that is using track pads don’t know the actual temp because my temp gun maxes at 650.
      05-21-2018, 09:49 PM   #36
Twt
Twt's Avatar
635
Drives: 2017 M2
Sort of....excerpt you can't just order new rings and reuse the hats.
      05-22-2018, 07:23 AM   #37
ZM2
Drives: 2017 LBB M2
I know it ratchets up the costs a bit, but I completely solved this issue by buying a lightly used AP Racing front BBK on the M3/4 forum for less than $3k. The AP Factory disc is 378mm x 36mm.
I ran the fuel tank dry in a long session (50min) and had zero fade with excellent modulation.
      05-23-2018, 07:02 AM   #38
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
Do you know if AP kit you have is compatible with 18" wheels, esp OE 513m ??
Current '22 X3M LCI..
      05-23-2018, 01:35 PM   #39
ZM2
Drives: 2017 LBB M2
I don’t know if it will fit that specific wheel, but it fits my 18x9.5 ET33 Apex EC-7s with no problem, even without a spacer. Apex wasn’t sure if it would work when I asked them, but it fits great.
I still think the main issue with the M2 braking is the caliper, not disc. Even with a slightly larger aftermarket disc, the caliper paint is still going to change colors and you’re likely to torch the dust boots like I did.
So, I went the BBK route and knowing early on the front M2C brakes were going to be too big for 18” wheels, I searched to find the largest disc that would work which is the AP Factory setup. The AP Essex kit is 372x34 with the same caliper, and I’m guessing it performs just as well. Both AP kits are way better than the M2C brakes, so good value if you can find them used.
The brake bias is slightly more to the front now, so maybe I’ll add the rear M2C brakes down the road. They’ll probably work with 18s and I’m guessing are a lot cheaper than a rear AP kit. Don’t really care for the M2C red caliper paint, tho.
      05-24-2018, 09:54 AM   #40
pruettfan
Where do you get a AP Racing big brake kit for 3k? I have only seen them just under 5k.
      05-24-2018, 10:45 AM   #41
ZM2
Drives: 2017 LBB M2
I’ve seen several used kits on the M2/3/4 forums for around $3k. The AP Essex kit is $4500 new, AP Factory is $6k new.
      05-24-2018, 02:58 PM   #42
Franzino
Franzino's Avatar
Belgium
861
I contacted headquarters of AP racing UK to learn more about their calipers and how the collaboration works between Essex and Stillen. This was the conclusion; Stillen is using the AP road car calipers and Essex the AP motorsport applications...
The range of AP calipers that Stillen uses are Radi-CAL 1 road car callipers (that can also be used perfectly on track). They are equipped with a protective paint coating, dirt seals, pad anti-rattle clips...
The Pro 5000R AP calipers that Essex uses is from the range that is aimed purely at motorsport applications , no paint finish, no dirt seals, no pad anti rattle clips
If you have a M2 that does 85% street and 25% track I would lean towards AP Radi-CAL road calipers from Stillen if you want AP brakes. I have AP brakes on my Z4M and they are amazing (braking on track with the same pads is the same as my friend his GT3 RS)
https://www.stillen.com/brakes/brake...mw-m2.html?p=1
According to AP racing headquarters; using motorsport calipers a lot on the street (year round) wil have some disadvantages and they are build for different purposes then street cars that see some occasional track time....it's designed for pure track cars and they need different maintenance/care, are more fragile (no paint finish / no dirt seals) and make more noise.
      05-24-2018, 03:08 PM   #43
ZM2
Drives: 2017 LBB M2
There are versions of the Pro 5000R calipers that have dirt seals and anti rattle clips. That’s what I have on my car. No ill effects running them on the road year round, except the DS2500 street pad dusts quite a bit.
Because of my experience with the stock M2 calipers, I’m now leery of painted calipers. The Radi Cal is AP tho, so maybe the paint will hold up.
      05-24-2018, 03:22 PM   #44
Franzino
Franzino's Avatar
Belgium
861
Thanks for the info...did your kit come originally from Essex?
