09-13-2017, 11:04 AM | #24 |
Rep 48
I also find 1-2 shifts tricky.
It feels as if there is too big of a spread in the gear ratios between 1st and 2nd. Or the revs just drop too slowly. To get a smooth 1-2 shift, I usually wait for 2 seconds and then release the clutch into 2nd. And yes, the gearbox tries to revmatch on upshifts, too. And it doesn't improve over time |
09-13-2017, 11:15 AM | #25 |
Rep 1,761
Drives: S2000, MacanS, M4CS
doesn't matter what RPM. you need more practice with MT.
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold Instagram: Tommys911 |
09-13-2017, 01:01 PM | #26 |
Rep 1,028
@msi200 To get a smooth 1-2 shift, I usually wait for 2 seconds and then release the clutch into 2nd.
Yeah this is what I resorted to at the very beginning It gets better slowly but it never feels as smooth as with the other gears |
09-14-2017, 10:52 AM | #27 |
Rep 48
Today I turned DSC completely off and am happy to report that this makes shifting 1-2 a lot better. It seems that the revmatch is causing this strange behavior, or maybe the different fuel map with DSC off?
09-14-2017, 01:57 PM | #29 |
Rep 1,608
Every BMW Ive ever owned featured this.. It's usually been made better by the now famous CDV delete... How come no mention of it here? Does the M2 not have one, or not have one that is removable?
Boostm3
09-14-2017, 02:16 PM | #30 | |
Rep 2,948
And man, if you think the M2 is clunky, the Z4MC is so much worse even with the CDV delete. |
09-14-2017, 02:27 PM | #32 |
Rep 1,608
Revmatch? You mean the automatic revmatch feature on downshift? How would that possibly effect the 1-2 upshift?
Boostm3
09-14-2017, 02:42 PM | #33 |
Rep 1,608
Seems to be absent. You have to wonder if that odious little piece was so valuable to the functioning of our cars all these years, how come now all of a sudden its deemed expendable?!
Boostm3
09-14-2017, 02:42 PM | #34 |
Rep 48
Revmatch also works when upshifting. On my car the gearbox shifts just fine with DSC off, in any other modes it is acting strange. So it should be either revmatch, the fuel map or both.
09-14-2017, 02:53 PM | #35 |
Rep 1,608
Revmatch on upshift? Ive never heard it described as that. .Besides, dont you usually accelerate into the upshift gear change? I dont quite see how an automatic rev match on up shift would work. Does it blip the throttle while your actively engaging the pedal?I guess this is getting rather confusing to me.
Boostm3
09-14-2017, 03:21 PM | #37 |
Rep 1,608
Interesting; Ill let you know once I take delivery next week.
Boostm3
09-15-2017, 02:05 AM | #38 | |
Rep 282
I finally began to slow down my 1st to 2nd shift and let the RPM drops before letting the clutch out and applying gas. Super smooth! Once you get used to it, you'll be able to speed things up. Start slow and work your way up. |
09-15-2017, 05:59 AM | #39 | |
Rep 931
Oh and the diff makes driving with DSC off so lovely. |
09-15-2017, 07:31 AM | #41 |
Rep 931
I find Comfort a very useful mode in medium-density urban traffic. Easy to drive smoothly, exhaust and pops are more hushed and the car is still plenty responsive and brisk. Each mode has its moments , strengths, weaknesses and purpose. I do think full personalisation and an ability to memorise a chosen setting between journeys would be helpful.
10-13-2017, 03:33 AM | #42 | |
Rep 660
From what I've gathered, the ECU is programmed to hold the revs for emission purposes, as suddenly closing the throttle will cause a spike in emissions. The downside is that the revs (especially with the large difference in ratios between 1 and 2) will not be at the correct rpms for a fast shift. I think I will practice slipping the clutch 1 -> 2 and shifting before 2k rpms so I don't have an awkward 2 second acceleration gap at every stoplight. |
10-13-2017, 06:13 AM | #43 | |
Rep 152
10-13-2017, 08:45 AM | #44 | |
7909
Rep 11,785
Have its own usage , this is extremely hamstrung by tying auto rev match to certain modes. That feature should be independently switched by the user , or at the least it should be available to be turned OFF in more than one mode. The delay issues from auto rev match are an interesting issue indeed. Perhaps this will help Latest ISTEP flashed.. much improved http://f87.bimmerpost.com/forums/sho....php?t=1427747 |
