11-03-2016, 07:06 AM | #23 | |
Rep 176
11-03-2016, 08:57 AM | #24 | |
Rep 3,009
11-03-2016, 12:11 PM | #26 |
Rep 844
right...what I'm saying is with traction control disabled by holding down the DSC button then it will create the most burbles and pop. By default the car has traction control on. So disabling traction control will create those sounds. In this case I guess its called "traction mode" meaning there is no traction control? Or is this the other way around where in "traction mode" it actually creates more traction control which is the safest setting you can put the car in?
11-03-2016, 12:26 PM | #27 | |
Rep 2,948
The burbles and pops are just a plus. |
D CHOI581.00 AndrewC198910949.00 |
11-03-2016, 12:47 PM | #28 | |
Rep 844
11-03-2016, 12:52 PM | #29 | ||
Rep 2,948
11-03-2016, 01:05 PM | #30 |
Rep 844
11-03-2016, 01:16 PM | #31 |
Rep 24
Is pressing the DSC button once equals to MDM mode?
When the car is in sport mode, it instantly go back to comfort whenever i press the DSC once,is that normal? |
11-03-2016, 02:04 PM | #32 | |
Rep 1,298
11-03-2016, 02:56 PM | #33 | |
Rep 1,017
I'm still getting used to all the modes. One thing I don't understand is when in comfort mode if you accelerate briskly away from a set of lights and then lift off the gas, the car holds the gear. It's comfort mode, why not shift up to the highest gear. Instead I have to tap the accelerator gently to tell the car to shift. In these instances I found PDK to be more in tune with what a driver is doing. Often in the M2 I'm manually shifting. |
11-03-2016, 04:43 PM | #34 |
Rep 290
11-14-2016, 10:16 AM | #35 |
Rep 337
Drives: '17 M2 DCT BSM
I feel like the most important difference between the 5 modes is actually the way traction and stability controls work. Throttle and steering do not change that much compared to other cars I've owned/driven.
- Comfort: all nannies on. - Sport: a bit more permissive than Comfort in terms of stability and traction. - Traction Mode and Sport+: both more permissive that Sport in terms of stability and traction. - Traction Mode: less permissive than Sport+ in terms of stability. - Sport+: less permissive than Traction Mode in terms of traction. - ESP-OFF: traction and stability controls are both off. This is my opinion formed from my experience with the car. PS: Traction mode should better be called "Cars and Coffee Mode" or "Mustang Mode"
Check out my M2 YouTube channel: The HyperCar Collective
11-14-2016, 10:34 PM | #36 | |
Rep 399
Drives: 2017 BMW M2 6MT
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
11-15-2016, 02:16 AM | #37 |
Rep 709
After reading all these posts about throttle response and DCT gear changes, I am sooo glad I've ordered a manual and will be able to change gear exactly when I want and select exactly the gear I want. Superior smirk.....
2011 Lotus Elise SC, 2002 BMW 330d, 1990 Caterham Super 7 HPC (sold), 1985 Porsche 911 Carrera SC (sold), 1978 Caterham Super 7 (sold), 1972 Triumph TR6 (sold), 1972 Jensen Healey (sold), 1965 Triumph TR4A (sold)
11-15-2016, 06:24 AM | #38 | |
Rep 2,856
MR |
11-15-2016, 09:58 AM | #39 | |
Rep 209
When I first put the car in gear, I get this weird "D" before the gear number. Anybody know that that means? It appears I can turn it off by either hitting one of the paddles, or the shift lever. |
4
11-15-2016, 10:10 AM | #40 | |
Rep 337
BMWM5NYC502.00 |
11-15-2016, 11:55 AM | #41 | |
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
Agree with your observations on full throttle! Prior to the diff swap I do admit to a couple of WOT runs and my butt dino, granted subjective, wasn't impressed! I guess I was expecting more. Anyone else? |
11-15-2016, 02:16 PM | #42 | |
Rep 709
11-15-2016, 04:10 PM | #43 | |
Rep 13,167
///M is art ↔ Artemis
11-24-2016, 12:12 PM | #44 | |
Rep 326
Have not taken delivery yet, just doing some reading on the driving modes. Just remember the attached chart. So MDM mode is activated by pressing the DTC button correct? From just above the chart in the manual it says: "The following states can be additionally activated by the DTC button: DSC on DTC on (M dynamic mode on) • DSC off " So can MDM mode be activated on any drive setting (comfort/sport/sport+)? I read earlier that if you put in MDM mode, it will automatically switch back to comfort. So does that mean MDM mode is always Comfort drive mode? |
