02-17-2021, 12:14 AM | #23 | |
Rep 12
-Eidos495.50 |
02-17-2021, 01:35 AM | #24 | |
@lbb_kev
496
Rep 516
As for the stage 3 hpfp, we internally call it "stage 3" because it outflows the current "stage 2" hpfps on the market (Dorch Stage 2, Spool FX180, Nostrum, etc...) by a significant margin. The vendor for the "stage 3" pump hasn't released it on their site yet.
05-06-2021, 10:58 PM | #25 |
@lbb_kev
496
Rep 516
An update today for everyone!
Up to a couple of weeks ago my car was down as we encountered some hardware design limitations on the stage 3 HPFP set-up. After four to five weeks of redesigning and development we got our hands on a revised set-up and went back to dialing in the calibration. It's now rock solid and capable of flowing full Ignite Red (E90) at power levels above what the BW 7670 EFR is capable of. Attached is a dyno graph on a mobile dyno on full E85 with 95+F degree ambient temperatures with only two fans blowing hot air at the cooling system - my poor turbo was struggling to breathe. Note that I have since switched to NGK SILZKBR8F8S's gapped at .018'' to avoid misfires that were encountered above 600whp last time on high e-content. You will notice that compared to the dyno graph posted on post #13 that the torque curve in the mid-range is much flatter/cleaner now. This is because with the help of SD Garage, one of the best shops for turbocharged BMWs in Southern California, we were able to take advantage of the downtime to partner with a well renowned Australian clutch company to create a twin-disc clutch for our cars (And 6MT S55s) to hold the extra torque. This won't be a review of the clutch so I will keep it short to avoid going on a tangent. It holds around 900 ft/lbs of torque, clutch pedal pressure is lighter than other currently available aftermarket equivalents, has light clutch chatter, and is daily-able. This paired with the Autosolutions SSK and Ultimate Clutch Pedal have been a pleasure to drive with. The fueling, clutch, tune from BendCalibration, and SD Garage's workmanship were all put to the test this past weekend at my first half mile event at NoFlyZone California. There I did over 13 runs (about 8 back-to-back) with IATs between 120F to 140F and a slight headwind. The car and clutch took it like a champ and enabled me to reach my goal of a 160mph trap speed on 3/4ths tank of E82 on the last run before closing time, which felt amazing. All in all, I think my goal has been reached for a fast DI-only / flex fuel capable daily that can be beat on at events. I may post updates with vendor news on the fueling solution or clutch in the near future. Maybe a new dyno graph as well since cookiesowns thinks we might be closer to 650whp (SAE)/ 663whp (STD) on the road on the current calibration since the mobile dyno conditions were so gnarly (We were desperate to get the calibration done since the event was happening on the day after). I want to give a shoutout, again, to BendCalibration and their awesome flex-fuel set-up and tune - no hesitations about e-content mixtures and whether or not I can beat on the car in the heat Also want to thank SD Garage again. The team there was extremely accommodating and diligent during the R&D process for the stage 3 HPFP set-up and the clutch. SD Garage is the shop that customers go to to fix other shops' mistakes and I will leave it at that
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage Last edited by -Eidos; 05-06-2021 at 11:07 PM.. |
05-06-2021, 11:48 PM | #26 | |
Rep 7,542
Commanderwiggin2056.00 |
05-07-2021, 10:35 AM | #27 |
@lbb_kev
496
Rep 516
It's an awesome set-up for sure. We'll hit the limit of the single Walbro 525 before we hit any HPFP limits. Will need to hook-up a LPFP sensor soon.
Commanderwiggin2056.00 F87source7367.00 |
05-07-2021, 11:29 AM | #28 |
Rep 1,204
Looks great! Time for some for a bigger war whistle!
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
-Eidos495.50 |
05-12-2021, 11:17 AM | #29 |
@lbb_kev
496
Rep 516
Once I get bored I'll probably build my motor and go for a bigger EFR turbo.
I'm not a fan of losing rev range from turbo spool so I'll probably want to extend the redline, reliably, to 7500-7800 if possible (Must be nice for you S54 guys!). Ironically, I already have to short shift a little bit after 3rd gear if I want maximum acceleration due to being out of the 7670's efficiency range. So if someone were to go a similar route, a 8374 would allow for better top end with slightly worse spool (Around 100-200rpm). Maybe this will be me soon: https://www.instagram.com/reel/CNoGL...d=ehssh9gpf0e6
F87source7367.00 |
05-12-2021, 01:30 PM | #30 | |
Rep 7,542
05-13-2021, 10:26 AM | #31 | |
@lbb_kev
496
Rep 516
There is also another reputable engine builder working with a reputable tuner in the scene that I've spoken to that hasn't had any short to mid-term issues with 8k redline...So it's doable. But even he doesn't recommend taking it to 8k consistently due to decreased engine longevity so I may just build for 8k rpm and run a 7.5k-7.6k redline.
F87source7367.00 |
06-02-2021, 03:18 PM | #32 |
@lbb_kev
496
Rep 516
For those that have been following the progress, I just got the okay from Dorch to let everyone know that they will be starting production on the Stage 3 HPFP kit soon!
06-02-2021, 03:32 PM | #33 | |
Rep 7,542
Great news! Always nice to seem the fuelling game continue to improve on the n55. Any hints on flow capabilities?
06-04-2021, 12:22 AM | #34 |
Rep 604
Exciting!! Time to start saving my pennies!
06-14-2022, 07:15 PM | #35 | |
@lbb_kev
496
Rep 516
https://dorchengineering.com/product...-hpfp-upgrade/ Official flow capabilities on the page linked above. And it seems like the tune adjustment is already available on BM3 and coming soon to MHD.
06-14-2022, 09:17 PM | #36 | |
Rep 7,542
///M TOWN22312.50 |
06-15-2022, 05:38 PM | #37 | ||
22313
Rep 8,732
Nothing short of amazing
F87source7367.00 |
08-20-2022, 10:51 AM | #38 |
Rep 3,715
Hey -Eidos, reviving your awesome thread!
I had a few questions about fuel injectors that hopefully will clear up any questions for other guys, too. First, could you please confirm if these are the OE-like injectors (EU6) for our M2? https://www.fcpeuro.com/products/bmw...-13647639994kt And, if we wanted to switch to EU5 for more flow, this is the correct version? https://www.fcpeuro.com/products/bmw...ch-13647599876 I see there are several EU5 options out there. Secondly, with a lot of guys starting to play with Emixes and stock, Stage 1, and Stage 2 turbos, where would you draw the line to say F10 M5 EU5 injectors should be used? In my case, I'm using BM3 Stg 2+ Multimap and flexfuel sensor on E50 with a TTE460 for 480whp to redline. Also running a Dorch Stage 1 with the updated HPFP tables that I worked on with Dorch & PTF, so small HPFP dip at tip in, but can sustain this amount of power even in winter. Logs & dyno chart here: https://f87.bimmerpost.com/forums/sh....php?t=1884838 I don't really plan to add more power, bc as you can see in the dyno chart the Stage 1.5 TTE460 won't flow much more than 480whp to redline. I could probably get a little more out of her by running E60-80 and getting more flexfuel sensor timing advance, but IMO the little extra power isn't worth having to change from the stock LPFP and I wouldn't run that high of Emix in the winter anyways b/c of long cold cranking. So, that's my specific situ, but wondered if from your testing you found a whp & Emix line that clearly showed it was time to use a different injector? Another reason I'm bringing all this up is my car runs strong but has been developing a worse and worse idle over the last year, and now it's bad enough the car can die and codes don't point to anything specific, just random misfire when idling (no misfire at WOT). We're changing plugs (NGK @ 0.027" is what I've been running and is going back in) to see if that clears it up, but I also picked up the Bend Calibration fuel filter setup in case what we're experiencing is clogged injectors from extended E85 use & no line filter. Anyways, curious to hear your thoughts on all this. Thanks! |
08-20-2022, 04:32 PM | #39 | |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
08-20-2022, 04:54 PM | #40 | |
Rep 3,715
Just trying to figure out where the stock injectors max out based on whp & various Emixes, bc I don’t plan on adding more power. |
08-20-2022, 05:11 PM | #41 | ||
Rep 1,243
08-29-2022, 01:16 PM | #42 | ||||
@lbb_kev
496
Rep 516
Hey ZM2 !
On my EFR 7670 and upgraded manifold, I tapped out the Dorch Stage 2 at 550whp on E40 with a tiny bit more headroom on stock injectors while running a fairly rich tune. On full E85 I imagine potential WHP decreases to 440-460whp (Think WHP curve as an upside parabola (X-axis being E% and Y-Axis being WHP with the peak being at E40). Maybe cookiesowns can chime in here. The clear line for me was wanting a trackable car with 510whp on full E85. If you want this, you're going to need to an upgraded LPFP, Dorch Stage 2, and upgraded injectors for fueling. If you want more, you'll need a Dorch Stage 1 or 2 with the lift kit upgrade. Quote:
ZM22839.50 |
08-29-2022, 01:28 PM | #43 |
Rep 3,715
Thanks -Eidos.
I rarely run a tank of pump gas, but recently picked up some Lubricity LX4 on Bend’s recommendation. New plugs & Bend fuel filter going in this week. If plugs don’t fix it, will service or replace injectors with stock since I don’t plan to go above 480whp on E50. |
11-07-2022, 07:06 PM | #44 |
@lbb_kev
496
Rep 516
An update to this thread and some new data we found.
To give an update, I upgraded to the BorgWarner 8474 EFR. The BW 7670 EFR above 600WHP was out of its efficiency range and generating excess heat on the track. The 8474 barely sweats at that power level and still retains great spool and daily driving behavior. I also switched from the Walbro 525 to the Walbro 535. Less heat and more flow due to the lack of a check-valve. Starts up fine on E85 in California. The last big change are coil packs and plugs. Before, I was running F8S flex fuel plugs gapped at .020''. Now I'm running B58TU/S58 plugs gapped at .025'' on B58 coils thanks to Nexsys' kit. Timing has never been better. As a recap on rest of the setup: Full E85, DI-Only: Dorch Stage 2 + Lift Kit, EU5 M5 Injectors, Walbro 535 as the primary pump supported by EOS EKP. Turbo Kit: Speedtech EFR 8474 with inconel shielding and custom lines by SD Garage Downpipe: Modified Fabspeed 200cell High-Flow cat Intake: Stock Tune: Bend Calibration First run not shown on the road-tuning map did 640WHP. Final numbers landed at 717WHP STD. Early to Mid-range power limited to be conservative since I'm stock block, but I like how the torque curve is flat. From here we quickly learned that the EU5 M5 injectors are now the bottleneck. Definitely could lean it out more, but that's not the goal . I have Nostrum Stage 2 injectors on the way which will give more headroom. We're also flying blind with the Walbro 535's flow rate so a LPFP sensor install is on the horizon. As always, definitely wouldn't have gotten this far without Bend Calibration and SD Garage's help, so I want to give them a shout out More to come.
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage Last edited by -Eidos; 11-07-2022 at 07:25 PM.. |
ZM22839.50 F87source7367.00 Possessed13.50 designatedposter175.00 ericlr1225138.00 VicF87OG72.50 InHousePerformance113.50 |
