12-01-2021, 03:10 PM | #309 |
Rep 922
Drives: '21 F87 M2C 6MT
Garage List 2015 MINI Hatch 5-door [0.00]
2021 BMW M2 Competi ... [9.67] 2023 BMW X5 xDrive40i [0.00] 2017 BMW X3 xDrive28i [0.00] |
so what's the recommendation on a true square winter set-up on an M2C with these? 19x9.5 ET28? running 245/35 tires?
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line |
12-01-2021, 03:17 PM | #310 | |
3593
Rep 6,819
Wheels: Front & Rear: 19x9" ET30 -Direct fit Tires: APEX Staff Pick: Front & Rear: 245/35-19 Performance Winter tire recommendations: Michelin Pilot Alpin PA4, Pirelli Winter Sottozero 3, Dunlop SP Winter Sport 3D, Vredestein Wintrac Pro With a 19x9" ET30 wrapped in 245/35-19 tires at all four corners, this setup will be a complete direct fit on a stock M2C and will have no issues clearing the larger 2NH front brakes. The 19x9" ET30 is a bit better suited for a 245/35-19 tire, as it allows for a bit more sidewall, resulting in additional protection for the rim of the wheel. With that same tire size on the 19x9.5" ET28, most winter tires will be a bit stretched, which isn't ideal for off-season driving. Hope this helps! -Geirsen
happyjack1657.00 |
12-06-2021, 03:43 PM | #311 |
Dirt Junkie
116
Rep 76
Drives: 2020 BMW M2 Competition
Pulled the OEM BMW wheels and tires (PSS - great rubber) and put Apex SM10 wheels (9.5 & 10.5 x 19) with Pilot Sport Cup 2 sneakers (265 & 295) on the car.
Been running the Apex EC7 with the same size spec R compound tires on the track and really like the feel. Came home from the track a couple of weeks ago, didn't change them out, did a bit of street driving with the track wheels and was blown away with just how much more traction they gave. Second gear rear wheel spinning was a breeze with the 265/35 PSS, now it's no spin and just forward momentum gain. My present PSS are worn out at 10.1K miles (inner front shoulders are shot due to finding a good track setup and not having camber set correctly last time - waaaay too much). I probably have 20% of the tread left front and rear. I'd always said I'd put new wheels on when it was time to change out the tires and since I like the Apex setup that's what I went with again. The sidewalls on the Pilot Sport Cup 2 are thicker/stand out just a tad more than the Toyo R888 so my spring perch adjustments are rubbing on the inside sidewall just a touch (about a millimeter). I'm waiting on 3mm spacers from Apex - should be here either tomorrow or Wednesday.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW-What a Ride!'" - Anonymous
4
10-01-2022, 11:27 PM | #312 |
MDM = Must Drive More
669
Rep 479
I waited for the OEM tires to wear down. Finally after a year (talk about patience) I swapped my OEM wheels with the Apex wheels I bought quite some time ago. Only got a chance to take one evening pic. I will post up some more daytime pics soon. RT660 tires are meaty. Give the car a formidable look and the combo is definitely track capable. Posted an install pic in comparison to stock for anyone considering this on Sunset Orange. This maybe the longest wait to put on wheels. I think I bought these two years ago. 😝
'21 M2 Comp
Sunset Orange | MT | Exec Pkg |
10-04-2022, 01:58 AM | #313 |
669
Rep 479
Daytime pic after work. I like the way these look for sure. Color changes quite a bit in different light.
'21 M2 Comp
Sundinisagod113.50 |
10-30-2022, 11:58 AM | #314 | |
Remove Before Flight
6925
Rep 1,616
(Right down to the wheels and IND side markers)
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
GarageMadness668.50 |
