03-11-2024, 09:12 PM | #243 | |
Rep 57
But yeah I don’t see anything out of the ordinary based on the logs either 🤔 |
03-11-2024, 09:46 PM | #244 | |
Rep 57
Thanks a lot for the writeup! I’ll go through the list and report my findings. Right now I’m running NGK 97506 plugs gapped to 0.022”, so I’ll start by checking the battery and re-logging (while monitoring HPFP duty cycle). |
ericlr1225138.00 |
03-12-2024, 08:04 AM | #245 |
Rep 3,715
Let us know how it goes. Halim just gave me a similar map as yours, so will see if it gives me issues and will post a log later today.
TUDMG24.00 ericlr1225138.00 |
03-12-2024, 12:32 PM | #247 | |
Rep 3,715
No issues on my setup, felt pretty strong. Will be curious to see how timing looks with the added boost. Doubt VD is worth anything, hard to find flat roads around here. 295/35/18. https://bootmod3.net/log?id=65f089b22a8768208b9e16f4 https://bootmod3.net/log?id=65f08a0250d755387291773f https://bootmod3.net/log?id=65f08a4439e97068e976609a |
TUDMG24.00 |
03-12-2024, 12:34 PM | #248 | |
Rep 255
If 22-23psi from 5k-6k. I think it's around 520whp-530whp. Timing is not suffering tho, 11.5degree at 6700rpm ish From my experience, you probably will hit injectors limit very soon, They are still working well at the moment. The only way to test it is to rev higher, both 4th and 5th. Last edited by ericlr1225; 03-12-2024 at 12:40 PM.. |
03-12-2024, 12:35 PM | #249 | |
Rep 3,715
Boost is higher, but timing is lower than the Stg 3 MM V1. I don’t know which approach is better. IDK if I’m pushing that much power. In my Stg 3 E50 beta 494whp dyno run we were pushing similar boost, but timing was slightly higher. That said, timing and power would crack up a decent bit up top on that map, so I stopped running it. Maybe this one is 490whp’ish with my TTE460. IDK. Last edited by ZM2; 03-12-2024 at 01:03 PM.. |
03-12-2024, 01:22 PM | #250 | |
Rep 4,218
Mods: Yes.
03-12-2024, 01:28 PM | #251 |
Rep 4,218
What tire brand
Mods: Yes.
03-12-2024, 02:09 PM | #253 |
Rep 3,715
Got my winter tires on still: https://www.tirerack.com/tires/conti...ct-dws-06-plus 295/35/18.
Altho, each of those runs were not on flat ground. 2017 M2, DCT, full tank of gas, no weight savings, 180lb driver. |
03-12-2024, 02:38 PM | #254 |
Rep 4,218
Sorry - The actual make and model. The tire size will vary by the make and model. Also factor for your weight. Is your car slicktop (no sunroof) Most M2s were weighed around 34xx depending on configuration. I have a profile for the DCT and 6MT and I will plot them both.
ZM2 - can you post a log you actually dynod with? That way I can calibrate it to Dynojet numbers. It going to be an apples and pears comparison - but they are both fruit so that has to account for something.
Mods: Yes.
03-12-2024, 03:00 PM | #255 | |
Rep 3,715
494whp log: https://www.bootmod3.net/log?id=6205...90c62156bfa6e3 While the 494whp log looks decent, you can see how quick power dropped up top, so I stuck with the 478whp tune, up until today while I'm trying out Stg 3 MM V2. So, I'm curious if you guys see much difference b/n my 494whp log and today's Stg 3 MM V2 logs? |
03-12-2024, 03:16 PM | #256 | |
Rep 57
03-12-2024, 03:18 PM | #257 | |
Rep 4,218
You need a custom tune. The issue here is what you're using your car for and what your needs are. You need to gain some efficiency somewhere. I think having a tuner who knows have to adjust valvetronic and cam timing is really valuable to unlocking additional power. It's not about knowing the maps - it's about actually understanding the concepts AND having first hand knowledge on what works on the track. Right now, this tune is a MAXIMUM effort street tune, it's not made for what you need. The guys who run this on a street make youtube videos holding the phone vertically with burbles turned up to maximum. You're not those guys. While you might not care for my recommendation, I think you should speak to Bob at StageFP (or anyone) Because you deserve better than this.
Mods: Yes.
03-12-2024, 03:21 PM | #258 | |
Rep 4,218
Mods: Yes.
03-12-2024, 03:25 PM | #259 | |
Rep 3,715
For the track, this is the last tune I was running, likely ~460whp and quite a bit less boost: https://www.bootmod3.net/log?id=64ee...0b430837cdaf22. Altho, I was still hitting 250F coolant on a 45F day at the track, so guessing swapping the intercooler will have to be tried later this year. Want to get more current track data first on these and lower power level maps to see what temps do. |
03-12-2024, 03:29 PM | #260 |
Rep 3,715
Yeah, not sure what to say about this. IDK if it's the road elevation change that's throwing VD off, but I have many dyno's above these power levels and a 7.2s 100-200kph to back it up.
Obviously I haven't dyno'ed (or Draggy) these b/c just got them today, but they def don't feel down on power. This is one of the reasons I don't really care to use VD. |
03-12-2024, 03:34 PM | #261 | |
Rep 4,218
Mods: Yes.
03-12-2024, 03:34 PM | #262 | |
Rep 57
03-12-2024, 03:39 PM | #263 | |
Rep 57
Yeah I’m still a little skeptical about VD. Unless conditions are near perfect, my personal policy is to refrain from posting them unless it’s to get an idea of power delivery (not exact power/torque numbers) |
03-12-2024, 03:40 PM | #264 | |
Rep 3,715
Take some logs at the track next time so you can check temps. Many variables at play that will impact coolant temps including ambient temp, grip levels, and how hard you're driving. To give an idea, I was doing 1:20s on Summit Main and 1:28s on NJMP Thunderbolt on the current 2+ Multimap on RE-71RS's. I've added coilovers since my last visit to Summit, so I expect to be in the teens on fresh rubber. |
