11-20-2016, 11:00 PM | #243 |
Rep 197
Subscribed
11-21-2016, 04:09 AM | #244 |
Rep 2,210
What's up with the Dinan website? I can't log on from either of my devices.
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
11-21-2016, 05:58 AM | #245 | |
Rep 906
What gives, Dinan?
1974 R90S (SOLD)
2017 M2 AW MT (SOLD) 2020 Tesla Model 3 Performance (SOLD) 2023 M4CX - RIP - WGI Turn 9 2024 M4CX - Week 39 |
auf Deutsch1913.00 |
11-21-2016, 08:31 AM | #246 | |
Rep 3,136
Jackie Chiles1000.50 |
11-21-2016, 10:09 AM | #247 |
Rep 906
It was probably the North Koreans.
1974 R90S (SOLD)
MilehighM3915.00 |
12-01-2016, 05:14 AM | #249 |
Rep 2,210
Tis December, any juicy stage 4 gossip?
No Boost4027.00 |
12-04-2016, 11:19 AM | #251 | |
Rep 2,577
What is the target boost your software sets at top end? Will a high flow DP and a good FMIC make meaningful gains with your stage 1 tune? Say extra 15~20WHP?
Lemania 2320
12-05-2016, 08:30 AM | #252 | |
Rep 3,136
Waiting on engineering to give its blessing and sprinkle holy water on the products or the sign of the cross or whatever they do in the time between when they verbally say stuff is ready to when its actually released ("paperwork bureaucracy" is the phase I call this).
We dont do any testing with modified CATs for emissions reasons so I really couldn't give you a concrete answer on the second question. In general the CAT's are the single most restrictive element in a system though so their removal, or going to a lower cel count version, would give you some power. |
12-05-2016, 11:12 AM | #253 |
Rep 1,122
Will you have enough intercoolers on initial launch? I live close enough to Morgan hill or your Mt view shops so I can go either or. If supply will be a minimum how can I be the first on your list?
12-05-2016, 12:43 PM | #254 |
Rep 3,136
Should have plenty for the initial launch. I'll put up the release when its imminent and you can contact Erin over in Mtn. View to get it scheduled/ordered.
12-05-2016, 12:51 PM | #255 |
Rep 2,210
And turbo supply?
12-05-2016, 01:48 PM | #256 |
Rep 3,136
Turbos are turbos--- there's never enough cores to go around. We are currently cycling through 28-29 cores for the N55 EWG. The non-M2 demand seems to be lessening though which will ease up the availability for the impending M2 demand. Given..its still limited.
12-05-2016, 05:47 PM | #257 | |
Rep 2,577
Now if you don't mind my coming back with more questions Though I Just wish I understand the load/target tunes difference...care to explain? Is load based tuning an exclusive Dinan feature? It looks to me a tune that brings out full potential of your hardware that's possible to a piggyback. Does that mean it effectively take advantage of the DP/IC or FBO setup? Then what's the difference in tune between Dinan stage 1 and say 3 or 4?
Lemania 2320
12-05-2016, 06:46 PM | #258 | |
Rep 3,136
Load based tuning is not unique to Dinan. Its simply the way the current generation of BMW DME's are programmed from the factory to make power. Instead of targeting a boost value it targets a load value (torque). So depending on altitude as an example that boost number needed to get to the load may be higher. At altitude and in thinner air the engine simply works harder to make the same amount of power that would be present at sea level. It does this by adding more boost until it meets its requirement. This is why a car in Colorado may be running 20 PSI of boost and a car in LA is running 16 PSI but they output the same power. BMW does this so every car no matter the conditions will be making the same power (in theory). In terms of the tuning (specifically Dinan) the stage 1 tune will not maximize the benefits of a FBO setup, particularly the DP because without the catalyst restriction the load target could be scaled up, which it is not, because our tunes assume a stock cat is on the vehicle. You will get some additional power from the car just because a restriction is removed but it would not be optimized for it. Stage 1 and stage 4 difference essentially comes down to the cap power is increased. I'll speak in boost just because it easier to illustrate. Stage 1 may have a peak boost of 15 PSI and stage 4 may have a peak boost of 23 PSI. Just because the hardware is on the car from stage 4 the tuning is still stage 1 the car will still be peaking at 15 PSI and not the 23 PSI. Its the same with load/torque. I'm horrible at illustrating more technical points. lol |
12-05-2016, 07:30 PM | #259 | |
Rep 2,577
BMW's load based approach for turbo engine is not new to us but it surprises me that a piggyback works the same way, though to be completely honest I am still a little bit skeptical on it. My understanding is that engine perform to piggyback preset boost/AFR targets with altered signals and has much less control on the power output it ends up making. Can you double check and confirm I am wrong?
Lemania 2320
12-07-2016, 10:31 AM | #261 | |
Rep 3,136
The only 2 other M2 products that I am aware of in the pipeline are camber plates and strut braces. No real news on either though. |
12-07-2016, 12:52 PM | #262 |
Rep 386
12-07-2016, 01:08 PM | #263 |
Rep 3,136
Stage 4, big turbo, and intercooler are all interrelated and have been being discussed for the last couple pages so I thought that was already implied. =)
12-07-2016, 11:02 PM | #264 |
Rep 446
Drives: 2017 M2 6MT, 2022 X7 M50i
Dinan_Engineering do you have any information about the decibel level for your exhaust with and without resonator delete? I will be tracking my car and some tracks have decibel limits.
