10-29-2020, 12:58 PM | #221 | |
Rep 70
Drives: 2021 HS 6sp
I switched to a 255/275 set up on my 17M2 using PS4's and felt like the car handled better not to mention the tires filled the arches better. I have PSS installed on my 21M2C and and plan to switch to PS4 at the first opportunity. I felt more confident on the larger tires. |
10-29-2020, 05:00 PM | #222 | |
6643
Rep 4,145
Drives: '18 M2 6MT
And yes, the PS4S will give you better performance no question, it's a much newer design tire. |
11-21-2020, 12:07 AM | #223 | |
Rep 1,523
245/35/19 BMW* = M2 BMW* DT1 = M2CS 265/35/19 BMW* = M4GTS BMW* DT = M2 BMW* DT1 = M2CS DT1 = new sidewall design and tread wear 240 |
CSBM52756.00 |
11-21-2020, 12:11 AM | #224 |
Rep 1,523
For the rear they used the BMW* PSS from the ZCP M3/4. For the front there is no BMW* PSS in 265/35/19 as the ZCP runs 20s all around. That's why they subbed it in with the 255/35/19 from the regular M3/4.
11-21-2020, 09:19 AM | #225 |
6643
Rep 4,145
Drives: '18 M2 6MT
Again, they used a 255/35 because the correct size of 265/30 wasn't available in the PSS.
11-21-2020, 07:54 PM | #226 | |
Rep 1,523
M3/4 255/35/19 (661mm) 275/35/19 (675mm) 14mm 2% difference M3/4 ZCP 265/30/20 (dia 667mm) 285/30/20 (dia 679mm) 12mm 2% difference M4 GTS and CS (Cup 2) 265/35/19 (dia 668mm) 285/30/20 (dia 679mm) 11mm 2% difference M3/4 CS 255/35/19 (dia 661mm) 285/30/20 (dia 679mm) 18mm 3% difference 265/30/19 (642mm) will be 37mm 6% different than 285/30/20. This combo will not work and there is no reason for BMW to select this combo. |
blkonblk202.50 |
11-21-2020, 09:02 PM | #227 | |
6643
Rep 4,145
Drives: '18 M2 6MT
Put your calculator down and go check the actual tread-widths and OD's. And regardless, this discussion isn't about an M3/M4 CS, so I really don't care what they wore or wear. |
11-22-2020, 10:54 AM | #228 |
Rep 2,408
Do you have any track time with these sizes I would love to run these w/o rubbing. Need to change tire for next season. My concerns are also around section width. I don’t like scraping off fender paint lol.
11-22-2020, 12:12 PM | #229 | |
Rep 1,523
Ok there, I must be seeing things here. Have yourself a great weekend. Last edited by M4_GTS; 11-22-2020 at 12:40 PM.. |
12-05-2020, 07:57 AM | #230 |
Rep 585
I finally swapped my stock contis for PS4S and increased the size to 255/35 and 275/35.
In my OG M2 with stock map, the contis could barely hold on in a straight line. Stage 2 it had no chance, and in the wet it was very nervous. The PS4S have been great so far - can hammer the throttle and it just goes. Will be interesting to see how it goes when I reflash stage 2, and also in the wet. Question - does anyone run coilovers and spacers with these sizes? I was running 12/10mm spacers but the rear rubbed occasionally. I did notice that the new tires poked a bit, as compared to the flush look of the originals. I've removed the spacers for now, but do feel they could be pushed out a little! |
12-05-2020, 06:39 PM | #232 |
6643
Rep 4,145
Drives: '18 M2 6MT
Not sure about the rub, as that has to do with how hard you hit dips, but you'll poke for sure. Remember, the 12/10 spacers are to flush the wheels AFTER a drop, which causes increased negative camber, and therefore needs some spacing to get back to where it was before.
01-10-2021, 12:24 PM | #233 |
Rep 1,477
Finally the PS4S is available in 285/30-19! This is definitely the way to go
01-10-2021, 03:37 PM | #234 | |
Remove Before Flight
6930
Rep 1,616
I just looked on Michelin's website and no joy on 285/30/19. Details? Availability? Link????
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
01-10-2021, 04:32 PM | #235 | |
Rep 125
Drives: 2021 BMW M2C
Garage List 2018 Audi TTRS [8.00]
2017 Porsche C4S [9.50] 2011 BMW 1M Coupe [10.00] 2007 Audi RS4 [5.50] 2004 VW R32 [6.50] 2021 M2 Competition [9.50] |
Honestly, I was getting ready to send Michelin an inquiry on why they don't make this size. I'm looking at purchasing new wheels, and I'm hoping this size will be available. |
01-10-2021, 04:34 PM | #236 | ||
6930
Rep 1,616
Still funny that it's not showing up on Michelin's US website.
01-11-2021, 10:07 AM | #238 |
6930
Rep 1,616
Sanity check:
Front: MP4S 255/35/19 on 19x9.5 ET28 wheel. Rear: MP4S 275/35/19 on 19x10.5 ET45 wheel. Lowered 1/2-3/4" maximum. Will it rub, or am I safe? TIA-- R. |
01-11-2021, 11:45 AM | #239 | |
Rep 3,844
Edit: I guess they do exist... https://www.onlinetires.com/tires/vi...yABEgLDXvD_BwE I couldn't find MPS4S 285/30/19 anywhere in the US Last edited by AlpsRider; 01-11-2021 at 12:39 PM.. |
01-24-2021, 10:01 PM | #240 |
Rep 84
Drives: HS M2C 6MT
Currently thinking of making the switch to 255/275 as well. Im currently on stock setup but with eibach springs (~1inch drop) and 10mm spacers all around. The fitment is perfect for my taste and I don't rub so I kind of want to avoid messing with it but I do want a bit more grip in the rear.
If I make the change to 255/275 will I have to get 5mm spacers to achieve a similar look w/o rubbing or should springs and no spacers do the job close enough? Also is it time to consider camber plates at that point after making the switch? I do a few track days a year so nothing too crazy. |
01-24-2021, 10:37 PM | #241 | |
6930
Rep 1,616
Honestly, after doing a ton of research, if you want a wider tire in back, go with the 265/295-30 combination. It's a bit shorter (smaller diameter) than the stock wheels, but is within tolerances and will give you more contact with the ground. You should be able to compensate for the wider wheel gap with that combination as you have lowering springs. Just my 0.02. R. |
01-29-2021, 08:05 PM | #242 |
Rep 1
Replaced Contis with Pilot Sport 4S 255/35 front and 275/35 rear, otherwise stock everything.
Rides much better on bumpy roads due to larger sidewall (+3.5 mm), also much improved grip in tight turns is fun. Just able to break the rear loose with DSC off. Here's some pics: Rear Conti 265/35 Rear PS4S 275/35Front Conti 245/35 Front PS4S 255/35 Conti side view PS4S side view Last edited by Carclassic; 01-29-2021 at 08:07 PM.. Reason: removed hyperlinks |
terrywang95.50 |
