04-16-2017, 09:52 AM | #199 |
Rep 185
Thanks guys...
Corolla is built to SCCA IT class rules, so the motor is mostly stock, just carefuly built. .040 over pistons, match ported, balanced, timed cams, blueprinted injectors, header etc. it probably doesn't make more than 140hp, but with the weight of it, it barely has to slow down for the corners on the race track. R8 V8 is nothing special in terms of speed, but still a very special car. The LS400 is a 91' LS shell, with 95' front calipers and my own custom wave rotors, my own design coilovers with Bilstein shocks, My own custom exhaust (side exit), SC300 Diff housing and R&P (better design and gear ratio), Supra TT Torsen T2 diff and 99 GS engine/trans/ABS (VVT, 50 more TQ/HP, better trans with flappy paddles). This is for the "24 hrs of Lemons" race series. Its 3,000lb, and is way faster and better handling than I thought possible. Its as fast as anything in the series, and will out corner and out brake pretty much anything. We typically blow by 3-4 cars under braking into every corner, often passing on the outside (its fun to see the reaction from the Miata and E30 guys) and can do that for 24hrs straight. Funny part is, I'm confident it would easily run with a stock M2 on track and even fully race prepped, I have under $5k in it (only paid $350 for the car to start with). The first picture is from "Car and Driver" magazine.. Last edited by Spinnetti; 04-16-2017 at 10:51 AM.. |
nd2002178.50 |
04-20-2017, 12:07 PM | #201 |
Rep 527
04-20-2017, 12:26 PM | #202 |
Rep 243
Actually I saw 114k on the BMW Blog.
M2 won't be the same though. I just hope they remove the ugly exposed CF, wouldn't enjoy paying 1-2k for that job. I am really curious to see how it turns out, as well as the Gran Coupe. Hope it sounds good too! |
04-20-2017, 10:27 PM | #204 | |
I INDIC8
612
Rep 1,290
Drives: 2018 LBB M2, 6MT
04-20-2017, 10:35 PM | #205 |
I INDIC8
612
Rep 1,290
FWIW, that second video is an 8J / Mk2 TTRS. Surprised it got as sideways as it did, although if they abruptly lifted throttle, they do love to exhibit lift-throttle oversteer under the right conditions.
04-21-2017, 09:43 AM | #206 |
Rep 243
04-21-2017, 10:58 AM | #207 | |
Rep 295
04-21-2017, 11:03 AM | #208 | |
Rep 1,153
Understeer can turn into wicked snap-throttle oversteer in a flash in some cars. |
04-21-2017, 04:55 PM | #209 |
Rep 295
Yes Had an Audi, so had to find ways to coax it to turn. Certainly not talking about foot completely off... I never had to go beyond maintenance throttle levels. But it does need to be sudden (but also smooth) enough that it upsets the car a little bit.
04-22-2017, 12:18 PM | #210 | |
Rep 1,427
04-22-2017, 05:15 PM | #211 | |
Rep 243
04-23-2017, 09:53 PM | #212 |
Rep 243
Was driving around tonight, it's raining and you can't see crap. Even in comfort mode, any pothole I took with the 435i felt truly horrible.
Why is this? Ride is too low? What's a nice plan B - the funnest you can have in a car that when it takes a pothole, doesn't feel like its tearing up the undercarriage? |
04-23-2017, 10:30 PM | #213 | |
Rep 295
04-23-2017, 11:09 PM | #214 |
I INDIC8
612
Rep 1,290
Not really de-accelerating, just lifting off the throttle very quickly after having been in it fairly deep.
You can get the back loose on a TT (any Haldex AWD nose-heavy car, basically) by abruptly coming off the gas. It will allow you to correct your line / help induce a turn a bit better. Because the car is so nose heavy, it will tend to naturally go back to understeering, especially once you start applying throttle again (the AWD system will help with this too).
04-24-2017, 08:49 AM | #215 |
Rep 243
04-24-2017, 03:16 PM | #216 | |
Rep 185
04-24-2017, 03:41 PM | #217 | ||
Rep 295
04-24-2017, 08:40 PM | #218 | |
I INDIC8
612
Rep 1,290
The magnetic ride in my (Mk2) TTRS is smoother over crap roads than my non-magnetic 2008 VW was, and far smoother than my brother's non-magnetic 2016 WRX... and the TT has less sidewall / larger diameter rims than either of those cars too. It's amazing tech. The beauty of MagneRide (the proper trade name for the system used in the TT; it's developed by Delphi Automotive) is that it allows them to use softer springs, and generate suspensional stiffness through the shocks alone. Normally to get a stiffer / flatter ride you need higher rate springs; conventional "adjustable" suspension can allow you to mildly tweak the response, but you can only slacken up a hydraulic pressurized shock so much. The valves inside these systems are also prone to failure over time; no such valves exist in magnetorheological shocks/struts. One press on the magic button stiffens it immensely (on the Mk2 TTRS there's no fancy customizable settings or anything, it is just normal and "sport" which is the stiff mode). I wish other manufacturers would jump onboard with this tech. It's one of the things GM has gotten very very correct lately. (Yes, GM did it first, Ferrari either licensed it or is buying through Delphi...)
04-24-2017, 09:26 PM | #219 | |
Rep 243
There has only been 1 TT RS before though, are you supoosed to say MKII? |
04-24-2017, 10:45 PM | #220 |
I INDIC8
612
Rep 1,290
It's based on the Mk2 TT body, so it's a Mk2 TTRS.
To get more specific you can call it the 8J TTRS, 8J being the internal Audi model code for the Mk2 TT. (I think the Mk3 TT is the 8S)
