02-12-2024, 03:06 PM | #199 |
Rep 320
is there a reason to get the pure inlet vs say the mst v2 or similar? I have the ftp v2 that fits and was made for ps2’s and the like….Just wondering if the new pure 750 inlet is thst much better….thanks
The inlet alone is like $300….Been researching on running an intake similar to what the full frame guys run..lurking on spul skreet |
02-12-2024, 08:22 PM | #201 |
Rep 896
Drives: OG M2
Yeah so I found a couple other PN's from the B58/S55 that I'm going to try tomorrow. Not sure why but it appears that realoem and bmw's own dealer ETK is literally incorrect. The PN's I'm trying tomorrow are 07129903804 (m6x10mm) and 07129905867 (m6x12mm). Hopefully one of these is the right one lol
02-12-2024, 08:43 PM | #202 |
Rep 896
Drives: OG M2
Wait, so to clarify, you're saying that the longer bolts go (1) onto the turbo side coolant hoses and (2) onto the block-side oil return line? The rest are all the shorter variant?
02-12-2024, 09:08 PM | #203 | |
Rep 261
So you can use the shorter one for the single lines on the turbo, the longer one for the 2 lines.
Speedtech top mount G35|Motive| Reflex plus | Wagner EVO 3 | BMP manifold | Dorch Stage 2 HPFP | PI | Precision Racework stage 4V2 LPFP | BendCalibration Flex Fuel Kit |turner catch can| HRE 20” \Apex 18” wheels| ECUTEK tuned by bendCalibration|ohlins suspension
IG Modded_M2 Last edited by Mr_M//; 02-12-2024 at 09:14 PM.. |
02-12-2024, 09:09 PM | #204 |
Rep 92
02-12-2024, 10:36 PM | #205 |
Rep 4,210
Do you have pictures? As far as I heard, the CTS was a copy of the MST, and was larger than the Pure and FTP.
02-12-2024, 10:43 PM | #206 | |
Rep 7,537
Does anyone have measurements for these inlets?
02-13-2024, 12:38 AM | #207 |
Rep 896
Drives: OG M2
Yup just confirmed that it was an m6 x 12mm bolt so it looks like the BMW ETK was wrong - thanks for the help!
Mr_M//123.50 |
02-13-2024, 07:59 AM | #208 | |
Rep 4,210
Pure and MST were tested and MST was better: https://f30.bimmerpost.com/forums/sh...2#post26317052
Mods: Yes.
02-13-2024, 10:58 AM | #209 |
Rep 320
Pure replied to my email..
“Hey Vic, its about 3" on the intake side and 3 1/4" on the turbo side” This appears significantly larger than other offerings. Arent they about 2.25” at the largest after reading Rays links. Turbo inley size, not tubing size.. |
02-13-2024, 11:08 AM | #210 |
Rep 7,537
Are they giving you an inner or outer diameter?
02-13-2024, 11:17 AM | #211 |
Rep 320
I have to assume the tubing diameter. Asked a more specific question and pointed them to this thread. Hopefully they(pure) chimes in or provides the specifics.
02-13-2024, 11:43 AM | #212 |
Rep 320
And…i may have just stumbled onto an interesting development..(not a good one).::awaiting pure’s response..But it appears as though there is a difference between a pure750 ordered with an inlet and one without..
02-13-2024, 11:56 AM | #213 |
Rep 4,210
Whoa. Preproduction maybe?
Mods: Yes.
02-13-2024, 12:13 PM | #214 |
Rep 598
02-13-2024, 12:29 PM | #215 |
Rep 320
Its true…
just talked with Ryan at pure. There’s the inlet that comes with the pure750 when ordering and the inlet they sell outright…they machine the turbo inlet side larger when you order the turbo+inlet together. If you don’t order the inlet they leave it about stock size to fit regular inlet tubes. Which is fing tarded cause anyone buying this turbo would opt for highest flow available… Getting an email verification with measurements of this inlet they have for a turbo like mine soon… |
M2guru425.50 |
02-13-2024, 01:35 PM | #216 |
Rep 320
Here you go;
There’s a difference(1/4”) & doesn’t appear the “stockish” one is all that different than current offerings. So, if you order a pure750..order the outlet with the turbo and verify you’re getting the big one. |
AmuroRay2373.00 ericlr1225138.00 |
02-13-2024, 01:37 PM | #217 | |
Rep 81
Wow, you’d think a this would be a cruital part of the marketing for this turbo. Shuenk is quite vocal about their inlet being proprietary to the N55+ and F55. |
VGSON222.00 |
02-13-2024, 03:07 PM | #218 |
Rep 605
02-13-2024, 05:55 PM | #220 |
Rep 1,389
Shuenk seem to be posting pump gas info last few days, almost like they're reading this thread.
These turbo manufacturers should be striving toward turnkey information for installs as much as possible. It's staggering. Almost as reluctant as McDonald's to list caloric content of their food! |
