09-24-2018, 03:06 AM | #23 | |
meow
120
Rep 156
Question about this, while there is no difference with the S55 variants, I do recall BMW stating that the M2 isn't able to handle the extra cooling required to get to M4 levels. Being from Australia, and certainly having a great deal of issues with cooling during the summer, do you think this is just BMW's excuse for detuning, or is there a real risk of insufficient turbo/coolant capacity? The engine may be able to handle it, but can the ancillary systems keep up? |
09-24-2018, 12:01 PM | #24 | |
Rep 2,787
I remember reading the M3/M4 bumper allowed more airflow over the OG M2. So BMW M set out to redesign the front bumper for the Competition, with improved airflow to feed additional S55 radiators. The new one piece grill is functional, increased airflow over twin kidneys by 40%. Lower grill openings are larger as well. Last edited by DieGrüneHölle; 09-24-2018 at 12:16 PM.. |
09-24-2018, 03:24 PM | #25 | |
meow
120
Rep 156
09-24-2018, 05:11 PM | #26 | ||
Rep 3,660
Drives: 981 Cayman GTS
BMW's statement regarding the cooling is their marketing excuse. Of course they are not going to say "We didn't make M2C available with the same HP as M3/M4 because otherwise it would kill our M3/M4 sales". Instead, they come up this sort of "marketing" explanations to justify the lower HP on M2C compared to M3/M4. Bottom line is M2 is a lower model than M3/M4 and it'll have less HP than an M3/M4 unless it's some limited edition CS/L. That being said, watch BMW offer a S55 M2 CS/L next year with 430+HP without changing a single thing in terms of cooling (maybe with just an air vent on a CF hood). M2C shares the exact same cooling hardware and mechanism as M3/M4, which is more than enough to handle much higher power levels. |
10-04-2018, 05:37 PM | #27 |
56
Rep 55
Drives: F90 M5,F85 X5M, F15 X5, F80 M3
bootmod3
Contact US @bootmod3nyc on IG
CTS Turbo Intakes/Downpipes/Chargepipes N55/B58/S55 | Lusso F90 M5 Downpipes/Intakes/Midpipes| Bootmod3 N55/S55/N63TU/S63TU Dealer ! |
10-05-2018, 05:08 AM | #28 |
Rep 49
Drives: M2 Competition/Evo 8 MR RS
Can this be detected by BMW?
MartyE12345340.00 |
10-05-2018, 09:19 PM | #29 |
4143
Rep 6,926
Some bootmod3 features.
- Revert back to Stock and locked. No chance of tamper code showing once flashed back. - No flash counter limitations - our dev cars have been flashed well over 1000 times. This has always been a BM3 feature. - Flash date freeze - unique BM3-first feature, no other tool supports today. Flash date never changes when flashing with BM3. - Flash counter freezes after OBD unlock But if they dig hard enough they can find anything. It would just take a lot more effort. |
10-26-2018, 03:26 PM | #30 |
Rep 163
Are there any dyno charts that compare the stock M2C versus the bootmod3 maps?
Also, I noticed on the website it states, "One OTS map/tune included with the purchase and any other maps labeled as "FREE"". Is there a list of maps that are free somewhere that I could see? Basically, I want to know whether it is necessary to purchase the extra maps for $100. |
11-03-2018, 03:01 PM | #31 | |
Rep 1,709
11-03-2018, 06:17 PM | #32 | |
Rep 551
Stage 0+ (M4 CS) Stage 0+ (M4 CSL) Stage 0+ (M4 GTS) Stage CS+ OTS maps (one free or $100 to unlock access to all of them): Stage 1 91 octane Stage 1 93 octane Stage 1 ACN91 octane (BETA) Stage 2 91 octane Stage 2 91 octane (AGG) Stage 2 93 octane Stage 2 93 octane (AGG) Stage 2 ACN91 octane (BETA) Stage 2 E30 octane Stage 2 E30 octane (AGG) Stage 2 Race Gas Stage 2H 93 octane Stage 2H E30 octane "H" maps are for upgraded turbos "AGG" maps feature aggressive burbles |
11-04-2018, 11:51 AM | #33 | |
Rep 2,808
Are there descriptions of the maps? And of the stages? Stage 2 is usually if you have a catless downpipe, right? And for the Aggressive burble, is there a note that says how it works? Is it just longer burble when you let off the throttle? Or louder? |
11-04-2018, 02:05 PM | #34 | |
Rep 551
The aggressive burble tunes require cats to be removed. I assume that the burbles are louder and more frequent, but I haven’t tried them yet. “CS+” is a new map with “more top end power” compared to the regular CS map. This map might prove to be the sweet spot for track days. |
11-04-2018, 02:23 PM | #35 | |
Rep 2,808
Is that it? Stage 0+ (M4 CS) Stage 0+ (M4 CSL) Stage 0+ (M4 GTS) And Stage 1 is more power. Are few running Stage 1 for track, because it's just too much power? |
11-04-2018, 02:29 PM | #36 | ||
IG @bmwF9xG80
3817
Rep 7,595
Stage1 or Stage2 maps can be run with stock cats, but any of the AGG Burble maps is recommended to have catless downpipe if used for long-term so you don't damage the stock cats.
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
11-04-2018, 03:50 PM | #39 | |
Rep 551
If you search around, you can find dyno comparisons between CS, CSL and GTS. The best option of the Stage 0 maps is the “CS” map, IMHO. I’ve used this map on track, and the power delivery is nice and linear. That said, I look forward to trying the new “CS+” map. FWIW, I use the CS map on track and the Stage 1 on the street. The ridiculous midrange torque of the Stage 1 causes wheelspin in the lower gears, but the passing power is effortless on the highway. This works great on the autobahn. |
11-04-2018, 04:07 PM | #40 | ||
Rep 3,660
CSBM52756.00 |
11-08-2018, 02:48 PM | #43 |
Rep 13
Hello, we have serious dct slip problems on a stage 2+ m2 comp. Tried to flash the gts sw to the tcu, but it has compatibility problems with the new digital dash. After 5 min of driving with the gts flash the dct stick to D mode, and the paddle shift and also the shift knob manual mode doesnt work. Do you have any solution to flash the gts sw to the new m2c ?
11-08-2018, 02:56 PM | #44 | |
4517
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
Tags |
bm3, bootmod3, m2 competition |
