01-15-2016, 04:18 PM | #23 |
Gone Fishin’
7318
Rep 12,125
01-22-2016, 02:42 PM | #26 | |
Almost completely sane
695
Rep 1,080
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) |
01-25-2016, 06:55 AM | #28 |
Dinosaur supervisor
3033
Rep 4,214
Yes, it it would be great if they would fit in the M4 sizes. They are about 10 mm more aggressive than the stock wheels so lowered they might be quite flush. But I think 275 up front might be a bit too much. I'm hoping they fit and would use a 255/35 front and a 285/30 rear or something like that.
02-22-2016, 04:18 PM | #29 | |
Rep 472
Hey guys... You made the car; you knew what would fit in those wheel tubs lol. You made the flares so you had full control. This guy acts like he is in the aftermarket. |
02-22-2016, 05:44 PM | #30 |
Rep 13,167
Uhm, "this guy" is one of the lead engineers at BMW M who developed the 1M and M2.
///M is art ↔ Artemis
02-22-2016, 08:35 PM | #31 | |
Rep 1,563
The real reason is probably twofold: 1. Reduce traction on the car to enhance the feeling of "playfulness" relative to the M4. 2. Reduce traction on the car to slow lap times relative to the M4 The M2 is only 6 seconds slower around the ring than the M4. With equivalent tires that probably drops to 3-4 seconds. Too close for comfort, considering the $25k average price difference. |
4
963mw331.00 |
02-29-2016, 03:03 AM | #32 |
Rep 3
horsepower_and_hounds1843.00 |
02-29-2016, 08:24 AM | #33 |
Rep 3,402
When they launched the car back in October one of the engineers said that they had to put a narrower tire on to make the clearances. He said they made the car as wide as they could. I don't see it as an issue, I suspect the car has plenty of tire based on what I have read and watched from Laguna Seca.
02-29-2016, 09:29 AM | #34 | |
7532
Rep 12,318
I think it would be naive to think that they didn't test wider tires and this is what they felt was more suited to the M2's personality. Or maybe as you said, this is an artificial way to limit it from the M3/4. Could be both.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
03-10-2016, 04:57 PM | #35 | |
7909
Rep 11,785
Being able to rotate all 4 corners really helps on wear and also the square setup help will have better grip and turn in and reduce understeer. For track I would start with 275/35/18 square. I have run Hoosier, Continental, Maxxis in this size.. I MUCH prefer P285/30ZR18 using Briddgestone R1 however, so if you want to go big check them out as well. Last edited by M3 Adjuster; 03-10-2016 at 05:57 PM.. |
03-10-2016, 05:23 PM | #36 | |
7909
Rep 11,785
I agree with you on the less is more concept except for on BMW turbo cars. Traditionally.. smaller and lighter has been the way to go on BMWs when it comes to wheels. With all the torque of a turbo layout as well as "overboost" ... I am firmly convinced that on BMW turbo cars... more tire is better, **everywhere**. Having more tire up front helps these heavier cars turn and not abuse their tires. Having more tire in the rear helps with actually putting all that M turbo power to the ground. The 1M and the M2 have MORE torque than the E92. Wheelspin at the rear is pretty much always gonna happen. No need to go with small wheels to reduce weight.. there is plenty of overboost to turn those puppies.. Were smaller tires fit on the M2 to help with playfulness... yes.. likely so... Will larger tires remove this playfulness ? hell no! Were smaller tires fit to help keep performance vs the M4 down? Yes.. I would bet so... Particularly for the 0-60 time with DCT. Want to see an M4 owner lose his head ..... would happen at every street light... Last edited by M3 Adjuster; 03-10-2016 at 05:29 PM.. |
03-26-2016, 03:18 PM | #37 |
Rep 1,963
If you look at the specs for these sizes on tirerack, the bmw specs for the M2 tires are really only .1 inch narrower, front and back than the M4 tires. The main difference is that they are shorter. As an example, the Porsche spec PSS 265 is over a half inch wider (tread width) than the bmw 275 that comes with the M4.
Current
AW BMW M2 Past VO BMW 1M |
03-26-2016, 08:31 PM | #38 |
Rep 333
Drives: 228i
Is this what they mean when the product blurb says "custom Michelin PSS" for the M2? Will it affect availability/cost of replacement tires? Sounds like you can just buy standard M3 tires when the current ones wear out
03-26-2016, 09:11 PM | #39 |
Rep 1,963
When I replace my tires and if I am still on the stock wheels I will buy the non BMW spec 255 and 275. They are much wider than the BMW spec. Check them out on tire racks website.
Current
04-16-2016, 11:41 PM | #40 |
Rep 3,009
According to the press release it was by design...
Made-to-measure wheels and tires. In order to transfer the car’s dynamic potential to the road as effectively as possible, the development of specific tires for the all-new BMW M2 was incorporated into the axle construction from the beginning of its development. BMW M vehicle dynamics engineers know that a certain set of factors take priority whenever dealing with high-performance sports cars. For example, the front wheels have to cope with different types of forces in terms of lateral stability and directional stability, while providing optimal steering feedback and steering precision. Likewise, the rear wheels deliver optimal traction, lateral stability and directional stability. After thorough testing development, the BMW M vehicle dynamic engineers decided to fit the all-new BMW M2 with aluminum wheels with mixed-size tires. The lightweight 19-inch forged wheels (front axle: 9J x 19, rear axle 10J x 19) substantially reduce rotating and unsprung masses. The exclusive 19-inch Michelin Pilot Super Sport tires measure 245/35 ZR 19 in the front and 265/35 ZR 19 at the rear. This set-up makes a considerable contribution to the outstanding dynamic properties of the all-new BMW M2 and, at the same time, ensures impressive everyday ride comfort. |
04-17-2016, 10:25 AM | #41 | |
Rep 796
I guess it comes down to whether you believe BMW would purposely crimp the performance of the M2 (to protect the M3/4 market) or whether they honestly want to get the best performance out of their car... and perform better against all other competitors. I lean towards the latter. Plus, I think the difference would be pretty much unnoticeable off the track. |
04-19-2016, 10:16 AM | #42 | |
7532
Rep 12,318
Think FRS/BRZ. They added skinny tires on purpose to make the car more playful.
Current:
04-19-2016, 02:00 PM | #43 |
Dinosaur supervisor
3033
Rep 4,214
I don't see why you would want wider tires. The cars has great traction and steers where ever I point it with such nice precision and it doesn't tramline at all. It is bloody marvelous!
04-19-2016, 02:14 PM | #44 |
Rep 1,963
I agree. Having said that, I want wider tires.
Current
